1978 - 1996 Big Bronco
edelbrock intake
Old Dec 5, 2011 | 11:28 PM
jonny_13's Avatar
jonny_13
Talking edelbrock intake
just slapped my 750 combo carb & intake on my 460, it was 18 deg f. today so the to say the least my rtv made end gaskets at least the frt one is leaking a little..anyone have any sureproof ideas besides ripping it all back off again???
Old Dec 5, 2011 | 11:36 PM
pintoches's Avatar
pintoches
It was a cold one! How did you like the snow!
I think the best thing to do would be to pull it and do it right!
Old Dec 5, 2011 | 11:39 PM
Encho's Avatar
Encho
The Southernmost Mod
Yeah, rip it off and start again... No really, there isn't such thing as repairing an RTV gasket, scrap the old RTV and use fresh one once again, just be sure to do it more carefully this time.
Old Dec 6, 2011 | 08:40 AM
jonny_13's Avatar
jonny_13
Yup you guys are right.. It always goes a lot faster the seconed time anyway right..new gaskets and more rtv it is.
Old Dec 6, 2011 | 09:21 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
This time, let it set up overnite before starting it up..
Old Dec 6, 2011 | 09:26 AM
jonny_13's Avatar
jonny_13
even if its going to be cold..? i feel like rtv isnt the way to go for end gaskets but edelbrock recommends it....? i'ld feel better just using rubber end gaskets regardless of what edelbrock thinks especially since the rtv leaked...i was a little premature on start up i only let it sit for an hour or two before start up.. big diff. though from 600cfm and stock intake
Old Dec 6, 2011 | 09:44 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Especially if it's cold. Everything takes longer as temp drops. You can tell a bit by feeling the stuff that squashed out after installation. Do all your final torqueing then let it set. don't go back and retorque once it's set.
Tip: Put four studs or headless bolts in and lower intake onto them. This will keep things from sliding around messing up the sealer.
Old Dec 6, 2011 | 10:05 PM
jonny_13's Avatar
jonny_13
soo. on that same note is it strange i have a dead spot @ wot, now that i put diff intake and more carb, it almost seems like its retarded a little would advancing it just a little cure that or would that be relatted to that end gasket not sealing..?hmmm..what do you guys think?
Old Dec 7, 2011 | 09:55 AM
Kemicalburns's Avatar
Kemicalburns
its more due to the vacum leak you have. get that taken care of before you run that thing to lean and hurt the motor. Then see where your at
BeauF0RD
15
Jun 8, 2017 05:35 PM
ironhead86
May 22, 2009 11:09 PM
missalot
Dec 31, 2003 11:37 AM
HangGlider
Jun 30, 2003 11:42 AM
51truck
Jul 24, 2002 03:12 PM
