How to remove the buttons on the Steering Wheel to check them.
Old 12-05-2011, 08:49 PM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
Im having CC issues and everyone's saying check the contacts
Old 12-05-2011, 10:12 PM
robs01f250's Avatar
robs01f250
robs01f250 is offline
Bump...Having the same problem and want to know how to complete this task
Old 12-05-2011, 11:15 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
I haven't pulled them on these trucks, but don't they screw/bolt in from behind the switches on the backside of the steering wheel and pull out as a switch assembly?
Old 12-05-2011, 11:16 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
i think if you search for air bag removal it will be in there with that. dont know for sure.
Old 12-05-2011, 11:20 PM
rocketman2440's Avatar
rocketman2440
rocketman2440 is offline
If I remember correctly, you have to remove the air bag, and they just snap in / out.
Old 12-06-2011, 05:26 AM
DISLFVR's Avatar
DISLFVR
DISLFVR is offline
Locomotive breath
Yes, look for that link. Did this myself last month. Not hard to remove the airbag, make sure your batteries are disconnected.
Old 12-06-2011, 07:47 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
What issues are you having?
Old 12-06-2011, 08:32 AM
Yougotthehit
It's not working. Replaced the sensor on the master cylinder and speed sensor. Also checked all fuses
jimmystoys
6.7L Power Stroke Diesel
17
01-03-2019 11:15 PM
Martin Broll
01-10-2009 11:32 AM
Roger T. Pipe
09-12-2008 05:41 PM
hedtrpr
1947 and Older Ford Trucks
06-19-2006 09:10 PM
Quick Reply: How to remove the buttons on the Steering Wheel to check them.
