problem with door handles
Old Apr 14, 2003 | 11:16 PM
nitemandick's Avatar
nitemandick
I have a 92 F-150 and in the doors it has a cable going from the inside handle to the door latch. Basically when you pull the handle its pulls the cable which pulls the latch open and the door opens. Both the cables in my truck snapped this winter. Ford had a recall on them back in the day but that no longer exists. Ford wants 70 bucks a door. I have beed thinking of replacing the assembly with the old rod type out of an 89 bronco that i have for parts. Will this work. The bronco has no power door locks and my truck does. Will this affect the power locks if i switch it over? I really dont want a cable again if its just gonna break.
Old Apr 15, 2003 | 12:06 AM
steve83's Avatar
steve83
You should be able to do that swap if the pushrod inside handles will mount where the cable handles are now. The power locks won't be affected.
Old Apr 15, 2003 | 01:45 PM
nitemandick
thanks steve. do you all agree. I am not doubting him but i just want to make sure. Pulling off door panes is a pain in the @$$. Thanks
Old Apr 15, 2003 | 11:42 PM
steve83's Avatar
steve83
I've swapped your style door panel into my old truck & it's not THAT bad - just a few screws around the pocket, one in the grab handle, & one by the vent window and the panel pops off.
