Power steering bracket needed
Old Dec 5, 2011 | 02:50 PM
zukinut's Avatar
zukinut
The parts truck was a 351m so the p/s bracket won't work. I need a p/s bracket and pump(if the pump is different than one from a 79) for an fe block. Need to get the p/s on my 68 so dad can drive it easier. Or is there a website that has used parts such as that. Can't get ahold of riff.
Thanks in advance
Will
Old Dec 5, 2011 | 06:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which P/S pump do you have? There are two different types, the brackets and P/S pressure hoses do not interchange.
Thru 1977, the pump has a steel reservoir, the P/S pressure hose threads onto the pump.
1978 and later: The pump has a plastic reservoir, is a different design and is smaller in diameter.
The P/S pressure hose has a straight end with an o-ring on it. Connects to the pump w/a qwik connect fitting.
Old Dec 13, 2011 | 11:05 PM
Freightrain's Avatar
Freightrain
Does it look like this? I pulled this from my '67 F100 with 352.
Old Dec 14, 2011 | 09:06 PM
HIO Silver's Avatar
HIO Silver
Canteen pump for an FE one-third down on this page: Power Steering Pumps and Alternator Brackets
Pricey.
GEARHEADS EXCLUSIVE
Pump, Brackets & Pulley for any 1958 and newer
Ford or Mercury FE Engines
Uses modern Saginaw pump.
Looks stock when installed.
Works great with Gearheads Power Steering.
Works with the original Crank Shaft Power Steering Pulley.
Pump has a low-mounting profile on the engine.
Has correct pump pressure for Gearheads Power Steering.
Includes Power Steering Pump Pulley.
This item sells for $395.00, including shipping anywhere in the Continental US.
Old Dec 14, 2011 | 11:22 PM
Freightrain
Oh crap, that's outrageous!!
I have the pump/gearbox as you see it above. I need to see if I kept the brackets to it? Not sure. If so, I'll make ya a deal on it. The pump has only a couple thousand miles on it before I scrapped the truck. Box is the same, fresh rebuild and still has sticker on it.
Pretty sure it still has fluid in it, don't think I pulled the new lines off when I pulled it out of truck.
ingo
26
Mar 11, 2025 07:59 PM
FourbyFord2018
16
Oct 19, 2018 08:27 PM
68murc
21
Jan 6, 2016 05:41 PM
jruggles
Vehicles for Sale
Jun 8, 2015 08:30 AM
greentruck72
Apr 28, 2015 09:21 AM
