HELP--2004 6.0 Diesel Going Dead!!!
Welcome to FTE! I agree with BPofMD. The tech folder is wealth of information to begin your diagnosis. I just purchased a ScanGauge II, and it has already paid for itself with the time I am saving chasing down the 6.0 gremlins on my 04.
There are plenty of knowledgeable members here who will get you heading in the right direction. With their help, I have completed numerous repairs on my truck. A little more info on your issues would be helpful.
Good Luck!
Good Luck!
The specific symptoms were the following. When cold no problems starting or running. After the engine came up to temperature, while driving, the engine shut down. I was able to restart it immediately the first two times it did this. The third time it happened I had stopped at a Dunkin' Donuts, shut the truck off, went into get a coffee and came out only to have the truck crank but not start.
I had it towed to a local Sullivan Tire shop that has done alot of my maintenance, such as tires, alignments, brakes, inspections etc. A young new tech they had was trained on diesels and he was going to be looking at it. 30 minutes after getting it to the shop the truck started right up again.
The engine had cooled enough to cause the fitting to conract enough to allow proper pressure to build in the HPOP. Brandon, the technician, pressurized the system and found the leak at the HPOP STC.
I am not sure that this issue is applicable to 2004's but I am guessing it may be. Due to the location of the HPOP, the labor to get to it and the cost of the part(s) the job cost me $899.00. Parts are not that expensive but the labor (the Ford estimate is 7.5 manhours for the repair if I remember correctly) is what gets you.
I would suggest looking in that direction and as the previous two replies suggested a Scanguage or other tool to monitor codes is completely invaluable. It is almost a must have!!
Eric
I have been going through a similar situation on my truck. I had a leaking D-Ring where the HPOP seats up into the cover. This was causing a loss of pressure affecting the IPR and ICP. 2 hours for tear down, $5 in parts, 2 hours to rebuild = tons of saved $
Where is the ICP sensor located on your truck? Early 04's will be located under the turbo. Later builds have the sensor relocated to the right valve cover. If the later situation applies to you, HPOP leak testing is an easier process.
Bad ICP, clogged IPR, and/or loss of high pressure oil will also have the same symptoms. Do a search on "HPOP leak" and "no start" and you will see that it is a common issue around here. Thread with ICP information for starters.
https://www.ford-trucks.com/forums/8...with-6-0l.html
Eric
I have been doing the same...AND I am actually learning it! Another 5 years or so and I will have it down! I think!
2000V10USER
03-18-2011 07:00 PM
