4.9L COLD STARTING
Old Oct 4, 2002 | 06:02 PM
HKH_6's Avatar
HKH_6
Post 4.9L COLD STARTING
Hello, first post! I just bought a 95 F150 4.9L. It starts and runs fine when warm. When cold it cranks a long time and kind of sputters until the engine finally cranks (about 5 seconds). It then fires up and runs great... Any ideas??? Thanks!!!
Old Oct 4, 2002 | 07:21 PM
HKH_6's Avatar
HKH_6
4.9L COLD STARTING
BTW, my fuel pressure is about 20 PSI when I turn the key on and about 50 when the engine starts, is this normal?
Old Oct 5, 2002 | 09:28 AM
HKH_6's Avatar
HKH_6
4.9L COLD STARTING
Update: I filled up and switched tanks (dual tanks) last night and this morning it started right up! Anyone know what this means?
Old Nov 6, 2002 | 06:19 AM
country boy's Avatar
country boy
4.9L COLD STARTING
Old Nov 7, 2002 | 08:27 PM
petroska's Avatar
petroska
4.9L COLD STARTING
I'm fighting a similar problem with my 87 F150 4.9L. Once the temperature drops below freezing in the morning, it won't fire until the temp rises above 32 degrees. It starts right up otherwise. I've tried dry gas, etc. Nothing helps. Doesn't matter which tank either. I'm thinking its a temperature sensor or a fuel pump/filter problem. Any other ideas out there?
Old Nov 7, 2002 | 11:08 PM
fastf150's Avatar
fastf150
4.9L COLD STARTING
nkh, chances are you got a bad fuel pump in that first tank. an old mechanics trick is to bang the tank on fuel injected cars and it gets the pump going for a while try this on the bad tank the next time you get a chance to cold start your truck.
Old Nov 7, 2002 | 11:12 PM
fastf150's Avatar
fastf150
4.9L COLD STARTING
petroska, try checking your IAC on your intake, if you have one malfunctioning or inoperative, it can give you a hard time on a cold start.
swmr1
Aug 2, 2018 07:15 PM
one_bolt_short
May 21, 2017 02:29 PM
carp49
Aug 7, 2016 09:12 AM
Lane Locke
Aug 2, 2016 05:28 PM
Tim Hodgson
Dec 23, 2015 07:08 PM
