Replaced Oil Pan Gasket Without Lifting Engine
Old Jan 7, 2017 | 11:20 PM
Realgraverobber's Avatar
Realgraverobber
I have to thank the generous knowledge given in this thread and forum.
I just completed this task, 1997 F150 4x4 4.2L V-6 manual transmission.
Removing the front axle through-bolts from the frame, and wiggling it down about 3 inches made the oil pan removal very easy. I did have to then remove the two 10mm-head bolts holding the oil pick-up tube from the engine block, and oil pan slid right out.
My problems were:
(1.) failed slave-cylinder-throwout bearing,
(2.) leaking rear main crankshaft seal,
(3.) and leaking oil pan seal.
Out came the: transfer case, transmission, flywheel, front axle slid down about 3 inches (easier than it sounds to do), oil pan, and rear-main-bearing cap (to remove the circular rear main seal).
Generous advice, mostly from experienced Ford technicians gave me the information to save my cherished pickup, asI wouldn't be able to pay someone else to fix it.
Old Jan 8, 2017 | 03:04 PM
Diesel_Brad's Avatar
Diesel_Brad
My problems were:
Thanks but NONE of anything you just explain pertains to these trucks. You might as well been working on a Chevy. a 97+ truck is COMPLETELY different
Old Apr 22, 2021 | 08:12 PM
Charlie Mountain's Avatar
Charlie Mountain
Any help is appreciated
Originally Posted by MAT4Ret
1996 F150, 4.9L I6; Everything I read said I had to lift the engine and remove oil pan which also meant removing the radiator and starter. This weekend I got brave and took a short cut. After jacking good and high with 2 sets of jack stands; I just unbolted the oil pan, removed and replaced the gasket. It was still a tough job and I spent a lot of time scraping and cleaning both surfaces. I was even able to reach inside the oil pan to remove some of the old gasket that fell in and wipe it clean. I used RTV all around the block and then raised the pan to smear RTV on both surfaces. Then I pulled the new gasket in place from around the oil pan, lined the bolt holes up and lightly torqued the bolts. I let it sit overnight and then instinctively torqued (no torque wrench) the bolts tight the next day.
I am proud to say no more oil leak and saved big $$$
I'm getting ready to continue my hunt for a missing distributor hold down clamp in the bottom of the oil pan. The bummer is that I don't have any leaks right now, and I'm not 100% convinced that it's down there. I don't need a new pump or screen (I don't think, anyways.) and the truck only has 130K on it. I've taken a 10 LB pull roller shop magnet all over, sprayed air, brushed out blind spots, and I cannot seem to find it anywhere.
On the bright side, I have a brand new set of engine mounts, as well as a transmission mount, so lifting the engine a little *anyways to do these, which are needed soon. I'm hoping to get away with pulling the intake to buy myself a little room and then dropping the pan as much as I can and sticking a magnet in there to retrieve the clamp before weaseling the new gasket on and closing it back up.
Hypothetically speaking, *if the clamp fell down the dizzy hole, but cannot be found right there in the vicinity of the hole, what might it have hung up on between the hole and the bottom of the pan? What is the likelihood that it made it all the way to the bottom?
Thank you for your time and attention.
Old Feb 14, 2026 | 06:18 PM
3nails4life's Avatar
3nails4life
1st Gear
Originally Posted by andym
But those are two different questions with two different answers.
"Do I need to lift the engine to replace the oil pan gasket?"
No.
"Do I need to lift the engine to replace the oil pump, change bearings, or replace the rear main seal?"
Yes.
So I still don't understand the confusion.
I also don't agree with the premise that "most people" who have to change the oil pan gasket also end up working on one of the other things you listed.
you will need to remove the transmission to replace the rear main seal
Old Feb 16, 2026 | 12:23 PM
knottyrope's Avatar
knottyrope
confirmed your confirmation on confirming it
Scott Stewart
25
Jun 8, 2023 11:39 AM
6.9 BLUES
Apr 2, 2014 12:21 AM
Lngbeard
Mar 31, 2009 06:23 PM
Dirt racer
Jan 9, 2009 04:54 PM
ALSAIR
Feb 11, 2005 06:18 PM
