Non conventional AIR CLEANER
Hello guys. I was at the j/y and was searching through air cleaners to put on my Qjet, which is on my 4.9, and was wondering what to do. I didn't really like the old metal type, and wanted to get one with a tube to a fresh air/cold air source. When I found this Cadillac air cleaner, with a '4.9' insignia, I had to have it. Now I just have to figure out how to fit it in the engine compartment/or if it will fit. Anyway, I really liked the look, so I think it is worth taking some time with.
Here are the pix:
If I decide it will work, I'll paint over the words around the perimeter of the emblem, and just go with the '4.9'. It was just too cool to pass up. I thought I'd paint the fins on my v.cover black to match.
Here are the pix:
I like the overall layout of the caddy airbox, except the small-ish inlet. If you can make the airbox and engine mate up, but build a bigger inlet duct, I think it would look/work great.
The small-ish size of the fresh air inlet duct would likely be a bit restrictive for WOT romps into the upper RPM range, however, properly routed to the front of the rad support would make for a true "cold air intake" system, and we all know that equals a bit more power and MPG.
moonshine34
26
11-17-2023 02:37 AM
JoeG
19
04-13-2010 07:23 AM
