Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- Buying Guide
Important information to help you understand your Ford truck
Buying a Used Powerstroke
#31
#32
I had a ton of people who told me to stay away from the 6.0L. But thankfully i did my homework and didnt listen to the idiots who were speaking to me without showing me the facts. Everything i was told was based off the rumors those people heard. I feel that since i had done my research that is why she is not only a beautiful truck but also runs great. I havent had one problem since i have had it.
#34
Received 3,166 Likes
on
or the egr cooler starts leaking.
or the EGR valve goes.
or until they will not start once warmed up.
or until the head gaskets start leaking and hydrolock the engine.
or until the rear seal goes. that one rite there is a $3,000 repair.
#35
If you replace the coolant with ELC, the oil cooler doesn't clog. If the oil cooler doesn't clog, the EGR doesn't fail. If the EGR doesn't fail and you treat the fuel and drive it properly and either keep it stock or use the proper tuner, the head gaskets don't blow.
#36
on
#37
Thanks for the info Zhilton. I didn't know what those acronyms stood for. (do now)
With all of these concerns about the 6.0 I wonder why Ford hasn't extended the warranty?
And, your everyday driver wouldn't even think of these problems, which in turn could be a cash cow for Ford! (repairs + parts)
#38
on
#39
Hey tjc, how in god's great earth do I have a BONE STOCK 6.0 with almost 300,000 miles and still with original:
Turbo
EGR Cooler
Oil Cooler
Head Gaskets
HPOP
and most of the stuff you say never lasts?
Strange.
Oh, and I'm tuned too!
Look, the bad trucks you had at that place, had one thing in common. They were abused, and not well/properly maintained. If you don't like 6.0's that's fine by me. You don't have to.
I have no problem watching people overpay for a 7.3 while I can get a steal of a deal on a 6.0 cause people like you feed bad info to so many people.
But really, if you don't like 6.0's don't talk about them.
Turbo
EGR Cooler
Oil Cooler
Head Gaskets
HPOP
Strange.
#40
I for one appreciate ALL the info here. Whether one has experienced problems or not, I think there is enough evidence in the market place to prove that the 6.0 has had problems, further evidenced by a lack of extended warranty in light of the manufacturer's knowledge of problems.
Now a lot of these problems may be exacerbated by the high performance products on the market place and their abused use, but a buyer like me has no way of knowing how previous owner(s) used or abused their trucks unless we gather info from sites like this one.
#41
90% of the 6.0 "problems" are the owner's lack of proper maintenance.
Now, one thing I would agree on is that the maintenance required is a bit much. But a properly maintained 6.0 is just as reliable as any 7.3. Oh, and way faster and more fuel efficient too.
firewoodtruck, that statement fits any vehicle and engine too...
#42
on
Turbo
EGR Cooler
Oil Cooler
Head Gaskets
HPOP
Strange.
some people have good luck with the 6.0.
the local ford dealership had one here that the owner used to tow his fifth wheel camper and plow his lot marina with.
he was the only one that drove it. it had 3 engines put in it with less that 35k miles on it before he switched to a gas engine
Look, the bad trucks you had at that place, had one thing in common. They were abused, and not well/properly maintained. .
Turbo
EGR Cooler
Oil Cooler
Head Gaskets
HPOP
Strange.
the only thing i can figure is they had extended idling time.
#43
And that's almost certainly what caused the problems. The 6.0L is not a good long low idle engine. Between wet stacking and EGR issues I strongly recommend against long low idles. If you need to idle the truck, do the high-idle mod and deal with the slightly higher fuel burn.
hink10
09-07-2012 11:21 AM
