have a .66amp draw
Old Dec 4, 2011 | 03:32 PM
mike L's Avatar
mike L
have a .66amp draw
I went to Autozone and had a free test done it said it had a .66a draw. Key was out, all light off, checked glove box light and trunk light to.
I removed the poss cable and waited 1 hour and tested between + cable and + post. I set my $15 digital volt meter to, red probe to 10ADC and black probe to com. Then set meter to 10A. I get a zero reading, even when turning on the dome light.
Old Dec 4, 2011 | 04:58 PM
projectSHO89's Avatar
projectSHO89
A .66 A draw is pretty normal for about 30-45 minutes after the last activity. You have to wait for the battery saver to time out before making any readings. The ammeter MUST be installed before entering the delay period.
I don't see a problem with the truck in your post.
Time for a new meter...
Old Dec 4, 2011 | 06:45 PM
mike L's Avatar
mike L
I got this amp reading after waited a few minutes before the test was done at Autozone. Should I have waited before having the test done, if so how long. Could the test be wrong? Battery, starter and alternator tested ok.
I got a quick amp reading from my anolog meter then it stayed at zero. Both meters still work on other settings.
The main problem was in the morning there was only 11 volts at the battery and we could tell that it started slower. After a drive it started fine, and the battery was fully charged. I there a short somewhere?
Old Dec 4, 2011 | 07:32 PM
Franklin2's Avatar
Franklin2
How did Autozone test for a amp draw? Did you watch them? You should get some sort of reading on your meter at all times. Zero is not correct.
Old Dec 4, 2011 | 10:45 PM
fmc400's Avatar
fmc400
MSEE
Don't do this on a negative-ground vehicle. Never remove the positive cable first. If your wrench shorts against sheetmetal or a radiator support, etc when you're pulling the positive cable with the negative cable still attached, the spark can ignite fumes that normally exist around an automative battery. In some cases, the current can be enough to split the wrench in two.
Always remove the negative cable first, and re-install it last. You want to perform this test between the negative cable and the negative post, not the other way around.
Old Dec 5, 2011 | 06:13 AM
mike L's Avatar
mike L
I got a print out after helping with the 3 min. test. Battery starter and alt. all test ok. Print out also said .66 draw, might be a short. I will try another meter.
thanks
Old Dec 5, 2011 | 06:35 AM
projectSHO89
Again, you have a 40 minute delay before the battery saver relay kicks out. Any current reading before that is not valid if checking for unwanted current draw.
Are you having an actual problem or concern or are you just curious about the AZ test results? In other words, do not make a problem out of ordinary operations or an improperly executed test.
Old Dec 5, 2011 | 06:38 AM
mike L's Avatar
mike L
bulb test
I redid the test with a small light bulb between the neg cable and neg post. The light bulb came on for a second then faded fast. Then lift ground wire and retested I get a dim light then fades fast again. Tried a third time and I got very little light which faded fast. Forth time no light.
Can't pull fuses with this kind of test, why does the bulb fade?
Old Dec 5, 2011 | 06:50 PM
projectSHO89
Seriously, what part of 40 minutes, needs further explanation?
Why are you even screwing with this?
Old Dec 5, 2011 | 07:22 PM
Franklin2's Avatar
Franklin2
I am assuming you are working on the 93? Your truck was in the beginning of the complex electronics entering the trucks. There is all kinds of modules with timers, memories, etc. If this was a 60's or 70's vehicle, you would have something to wonder about. The later ones will always have a small draw, and as you are finding out, can have a large draw for a period of time before it times out. The light fading out is a hint that everything is normal. A large draw would keep the light bright.
Old Dec 6, 2011 | 10:00 AM
mike L's Avatar
mike L
Update:
Sorry I did the test wrong. I charged the battery (draw drains battery over 7 days). Now I got the bulb to stay on all the time, between the neg cable and post. To stop the draw I removed the fuse for interior lighting. Remote doors, cargo light, doom light and chime don't work now. How do I test lets say the doom light, to see if there's a circuit short? Do I run a wire from the poss post the the doom light?? How do you test a relay.
Old Dec 6, 2011 | 06:28 PM
Franklin2's Avatar
Franklin2
How long are you watching the light when it's bright and you are doing the test?
Old Dec 7, 2011 | 12:08 AM
mike L's Avatar
mike L
The bulb was only a couple of minutes before I found the right fuse.
Old Dec 7, 2011 | 12:22 AM
Rebuild101's Avatar
Rebuild101
Check wires under dash for mouse chewing on them
Remember 40 min for saver
Old Dec 7, 2011 | 02:22 PM
mike L's Avatar
mike L
I connected the bulb between the neg cable and post. Should a wait 40 minutes to see if the bulb is still on. I think the bulb will always stay on because each morning the battery is weaker by a few volts. How do I test the doom light, with the fuse out. To see if there's a circuit short? Do I run a wire from the poss post the the doom light?? How do you test a relay.
