Starter cable gauge?
Old Dec 3, 2011 | 05:14 PM
Rose Clifford's Avatar
Rose Clifford
My starter cable broke off at the solenoid. The copper piece at the end that goes onto the terminal on the solenoid is what broke. What gauge is the wire? I'd like to replace just this piece instead of the whole cable. Anybody have a cheap place for getting parts like this? Advance auto didn't have it.
Old Dec 3, 2011 | 05:29 PM
mueckster's Avatar
mueckster
It should be a 2/0 cable. It might be hard to find a lug that is bent at a 90*. O'Reilly's shows the straight ones. You could buy a straight one and try to bend it before crimping it on.
Old Dec 3, 2011 | 05:31 PM
Rose Clifford
Thanks Roland,
I didn't even realize it's a 90. It broke right at the angle. I have a 'lug' that says 2 on it and it's way too small. I'm guessing it's got to be at least 0
Old Dec 3, 2011 | 05:39 PM
mueckster's Avatar
mueckster
Yep. 2/0 is the next size up from "0". We use 2/0 and 3/0 on the the OTR and Offroad equipment at work. We have some 3' long crimping pliers for them. We even have one truck that has dual starters.
Old Dec 3, 2011 | 08:05 PM
Dean88's Avatar
Dean88
The lug that has a 2 is 2 guage. Go to an industrial electric shop, theyll make what you need.
Old Dec 3, 2011 | 11:18 PM
snakedoc's Avatar
snakedoc
carquest might have it they have a lot more the Advance auto
Old Dec 4, 2011 | 05:45 AM
Tugly's Avatar
Tugly
Example: Platt or Consolidated Electrical Distributors
Old Dec 4, 2011 | 02:46 PM
Josh88Ford's Avatar
Josh88Ford
https://www.ford-trucks.com/forums/1...batteries.html
The only problem you will run into is the passanger side battery terminal. The power cable from the starter, and bridge cable9going to the drivers battery) are fused together into the terminal. You will either have to cut and solder into the exisiting part of the cable, or get a new terminal. I am running Knukoncept battery terminals, but am not very happy with them.
Old Dec 4, 2011 | 05:02 PM
badhabit1's Avatar
badhabit1
Had exact same thing happen to me! Any electrical supply business should have what you need, or farm and fleet, tractor supply, etc. Put new connector on then ran a completly seperate 2 gauge wire from passenger battery to starter just for complete piece of mind. I believe in overkill, lol!
Old Dec 4, 2011 | 08:07 PM
Dean88's Avatar
Dean88
I dont mean to be an ****, but I believe you mean 2/0, not 2 guage.
Old Dec 4, 2011 | 08:15 PM
Dean88's Avatar
Dean88
If you have time to wait, this company builds kicking wing cables. I run a set of 3/0 cables on my sbc, and have had zero problems.
Old Dec 5, 2011 | 04:12 PM
badhabit1's Avatar
badhabit1
No, I meant 2 gauge. Or 2 AWG.
Old Dec 5, 2011 | 04:18 PM
Dean88's Avatar
Dean88
Oops, sorry, just went back and reread your post, I see what you were talking about. I ve just had tons of problems with parts houses with 2 gauge & 2/0 confusion. I guess I was an ****
Old Dec 5, 2011 | 04:20 PM
badhabit1's Avatar
badhabit1
No biggie.
Old Jul 16, 2018 | 11:45 AM
johndoejoe's Avatar
johndoejoe
Neutral safety switch
Lots of nuetral safety switch stuff, but no videos or instructions of where the damn thing is, and how to get it out . . . am I inherently supposed to know this?
76 Highboy Ranger XLT
help!
Jersey
