Sponsored by: Real Truck
E Brake problems
Old Dec 3, 2011 | 05:00 PM
TruckNorris's Avatar
TruckNorris
E Brake problems
I had planned on installing new rotors and pads on my truck myself this weekend while on duty at the fire station. But while i was driving this morning to meet a friend to go to a firefighter expo today, there was a big weight shift in the back accompanied by lots of shaking and a loud grinding noise. So thinking this is probably more than what i could handle i decided to go straight to my fire house where luckily there is a repair shop next door. I drop my truck off at the shop for them to check out. They call later and say that the driver side ebrake basically disintegrated and lodged itself within the housing. The shop said that not only do i need a new e brake assembly but i need a new mounting bracket and that requires axle work. So i was wondering if this was an accurate statement and if so, how much work would actually be involved in this process?
Thanks,
Boyle
Old Dec 3, 2011 | 10:07 PM
Maxium4x4's Avatar
Maxium4x4
I bumped you to Superduty from the 6.0L engine specific forum for a better answer. Welcome to FTE
Old Dec 4, 2011 | 11:03 AM
saz2686's Avatar
saz2686
Sorry I don't have an answer. Just wanted to say welcome to FTE and you have a great user name. Reps sent. And good luck with your problem.
Old Dec 4, 2011 | 12:21 PM
TruckNorris
thanks, i appreciate it
Old Dec 4, 2011 | 12:48 PM
Ricson's Avatar
Ricson
I had the same thing happen to mine. The parking brake backing plate rots then the pins that hold the parking brake shoes pull out leaving the shoes floating around in the brake drum. To replace the backing plate the axle and hub has to be removed.
Old Dec 4, 2011 | 01:37 PM
TruckNorris
Dag, so I'm guessing that's a pretty lengthy process to fix it?
Old Dec 4, 2011 | 02:21 PM
Ricson's Avatar
Ricson
check this thread https://www.ford-trucks.com/forums/1...-pictures.html
Old Dec 4, 2011 | 02:42 PM
TruckNorris
Wow, awesome write up. Unfortunately I don't have any of those special tools myself so I guess I'll have to have my local shop change them out for me. Thanks a lot for the info, I appreciate it.
Boyle
Old Dec 4, 2011 | 04:07 PM
Quad Racer's Avatar
Quad Racer
Great handle there trucknorris.
Old Dec 4, 2011 | 04:15 PM
TruckNorris
I wish I could say I created it myself but I heard it somewhere else...just got lucky enough that no one else registered it first haha
wizzy00
General Diesel Discussion
Jan 13, 2015 06:22 PM
TLindquist
Dec 19, 2007 12:00 PM
juventus
Jul 25, 2006 07:58 PM
jkoj
Jul 7, 2006 03:15 PM
mino54
Computer Chips & Tuners
Jan 1, 2005 09:01 PM
