I have a 2003 f250 diesel. I recently finished taking out the cat and the muffler and replaced it for two four inch pieces of pipe. It made the truck a good bit louder but i have noticed a problem with the turbo. It is almost like it is loosing pressure and once i get up to the speed i want it stops until i increase my speed or climb a hill. This awesome happens when it is sitting in the driveway idling. Any help would be great because Im new to the diesel world and I dont know much about them
First Off Welcome to FTE
lots of great info and help here stick around and you will have that truck figured out
Do you have any gauges
you may want to look into scangauge 160.00 and does a ton of stuff best deal out there IMO
Like Benny said, welcome to FTE.
That's what a turbo does, really. The more load put on the motor, the higher your boost will be (within limits, of course). When you get up to cruising speed, the turbo won't be working as hard. Can you describe what it's doing while idling that makes you think something is wrong? Does the exhaust note change? Not sure you've got a problem here...
take it to an auto parts store and have them scan it for codes
the thing is the turbo uses the exhaust gas to spin the turbine so everything B4 it must be working correctly for proper turbo operation injectors, fuel system, air intake and so on......
To me its hard to point the problem being turbo relaited without a code or some gauges to see how much Boost it is or is not making
Do you still have an egr valve have you tried to clean it if so if its stuck open it could cause a power loss
I cleaned the egr valve. And the turbo was taken apart and cleaned about a month ago. Could there be an issue with back pressure build up since i have take the cat and the muffler out of the exhaust
Everything was running fine until i cut out the muffler pipe 3 days ago. Thats why i dont think it is any of my sensors acting up. And there are no codes coming up when i scan it
