Using diesel kleen and howes at the same time
On my last fillup i had put some diesel kleen in and now the tempertures are suppose to get to the low teens and im going to be driving my pickup to work since we are getting snow. I was wondering if it is ok to to use howes and diesel kleen at the same time in the same tank? we have not been getting blended fuel yet
Yesterday I was at half tank and topped off with a mixture of Diesel Kleen (40 gal) and some Howe's (recommended dosage). It started and drove well, but this was during the day...
The proof came this morning when it was 38 degrees; I cycled the glow plugs twice, tuned the key and it fired as if it were a warm summers day. The drive to work this morning was even more pleasant as the throttle response was smoother and more responsive.
I got to work, parked, and listened to the injectors for a min and they really seem to like the mixture.
Therefore, the consensus (as far as I'm concerned): mixing Diesel Kleen and Howe's Diesel treat is a good thing to do in cold or hot weather.
First Freeze
This morning I came outside to find this on my truck:
After cycling the key three times, with the mixture of Diesel Kleen (gray bottle) and Howe's, it started up nice and smooth even though it was *29 degrees out.
Btw, see all that ice on the windshield? Screw having to scrape it all off, this stuff works! Normally when you turn on your windshield wipers and use the washer fluid, it freezes, but this stuff got rid of the ice in no time at all!
Attachment 44979
Attachment 44979
I have to wonder about this "cycling the key" thing. I don't get it.
I go out, turn the key on, wait for the glow plug light to go out and crank it over. It starts every time and, so far, the lowest I've done this at is 0 degrees with no block heater.
If you have to keep the glow plugs on so long to get it to start, it seems to me that something is wrong.
Should have some frigid tempuratures on the morrow, I'll do things your way and even youtube it
Actually he is helping the engine get warmer...just by the amount of time it's taking for the light to "time out" the 2nd time. It's the length of time the GP are on that are helping. But I agree, the truck should start after the light goes out the 1st time.
Welcome to FTE.Some what, most places start selling what's called "winter fuel"...supposed to have anti-gel mixed in. It doesn't burn as well as what is called "summer fuel" so your mileage will be down some. Add to that if you idle your truck extra for it to warm up...that burns more diesel. I can just about point to it on my fuel log when the change takes place...I usually loose about 1 to 2 mpg when it happens.
