Isn't the whine from the turbo when the tranny downshifts during braking the most incredible sound?!? I turn the CD off and open the windows just to hear it! {Please forgive a diesel newby"s enthusiasm for his "real" truck} 900 trouble-free miles so far, and still haven't been able to put enough wieght-logs-in the back to tell.
Originally posted by johnsdiesel Of course it does. All the new 5 speed auto does is imitate how you would use engine braking in a manual transmission.
I didn't explain myself. I have heard that the new VVT acted somewhat like an exhaust brake, electronically manipulating the vanes to create backpreassure. This could be achieved in an auto by using the same signal the pcm gives the trans to downshift. I wondered if it really worked that way or not?
Originally posted by mjstef I didn't explain myself. I have heard that the new VVT acted somewhat like an exhaust brake, electronically manipulating the vanes to create backpreassure. This could be achieved in an auto by using the same signal the pcm gives the trans to downshift. I wondered if it really worked that way or not?
I hadn't heard that about the turbo, but I could be wrong. I think the towing mode affects only gear changes, not the turbo. I'd be surprised if they used exhaust brake type effects on the engine because Ford specifically says not to use an exhaust brake on all of the Power Stroke engines.
The Exhaust brake on a 7.3 is a non-issue. I know Ford dealers that install them. My 2000 has 100,000 miles on the clock, 60+000 towing with an exhaust brake and it has never been in the shop for anything. My 95 had 170,000 on it when i sold it. I do wonder about the 6.0 and an exhaust brake and the more complicated turbo though.
mjstef, an exhaust brake IS an issue. Remember, Ford Motor Company holds your warranty, not an individual dealer. Here's a notice by Ford regarding the issue:
SSM # 10389 states: "Some aftermarket products may cause severe engine and/or transmission damage. There are various manufacturers offering devices to increase turbocharger boost, exhaust brakes to increase stopping/hauling capacity or other such devices to increase the power/torque of the 7.3L DIT. Severe powertrain damage may result from use of these aftermarket products, which will not be covered by the Ford warranty."
"IF" An aftermarket product causes failure. Not "JUST" because you have it on. Like I said 270,000 miles between 2 trucks without a hitch. Chip, Exhaust brake,Ram-air ect and my dealer has no problems with the products. BUT,,,, IF i run the crap out of the truck with the chip and burn up the turbo, NO Ford will not pay.
Interpret it how you want, but it's all there in black and white. Some dealers might not have a problem with it until there is a warranty concern simply because they are selling you the products. Certain parts of the engine are not made to handle the backpressure that an exhaust brake gives and can fail (I think lifters and a few other things). Call Ford and ask them what there policy is and they'll quote what I just posted.
"Severe powertrain damage may result from use of these aftermarket products, which will not be covered by the Ford warranty."
The Ford EBV valve is what i use as an Exhaust brake. There is no more strain engaging this as a brake than when the PCM engages it at -20 degrees to warm the engine up. Mark wildman From Navistar told me at our rally 2 years ago that the EBV would not cause damage engaged until well after the redline of the engine.
Originally posted by mjstef "Severe powertrain damage may result from use of these aftermarket products, which will not be covered by the Ford warranty."
If you're using the EBV for an exhaust brake that's a lot different than using an aftermarket exhaust brake. I still would not expect Ford to cover any damage that might occur under the warranty though because you have modified the engine in a way that they are allowed to void that service work.
If Ford made the braking better on these trucks no-one would be putting these things on. Until then they will. It feels real good going down an 8-10% grade at 40MPH with the Ex brake on not having to use the service brakes at all. On the other hand the same hill at 25mph without an ex brake gives me a real bad feeling! If you pull gross weight across colorado and Montana you will know what i mean.
