MINI Spools are useless!!! and they break often. All they do is replace the spider gears effecitvely. If your going with a spool get a full spool. The mini spools isn't a step between full spools and locking diffs.
this well tell you what axle you should get. of course this is for there aloy axles and not stock but if your not anywhere close to the 31 spline numbers i would stick with 28
