Clicking during turn
Old Apr 14, 2003 | 03:36 PM
tdf138's Avatar
tdf138
Question Clicking during turn
Hi everybody
Newbie here with a question ....
I hear & clicking sound coming from the front end of my 99 Ranger whenever I make a sharp, low speed turn (like when Im turning into my driveway)
And sometimes I actually feel it thru the floorboard.
Can this wait till my next trip to the garage or is it something to attend to asap ?
Thanks in advance !!!
Old Apr 14, 2003 | 04:17 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
Is this a 4x4 or 2wd.
Old Apr 14, 2003 | 09:57 PM
jfarmer's Avatar
jfarmer
I have a 4x4 and i notice the same thing. It sounds like a popping in the front end. Mine also does it at low speed sharp turns or while im reversing. Sounds like the HUBs
Old Apr 15, 2003 | 07:47 AM
tdf138's Avatar
tdf138
Hello Ken00 ,
Sounds like jfarmer & I have the exact same problem , only mine is a 2wd.
Old Apr 15, 2003 | 08:13 AM
bkarr2000's Avatar
bkarr2000
Mine was doing the same exact thing. I had it at the dealer for something else, and I was in the garage with the mechanic. He took my driver side wheel off and tightened the upper control arm up. I told him that I had been experiencing a popping sound when turning and he said that might have been it. It hasn't popped once since then.
My truck is a 99 4x4 3.0L.
Old Apr 18, 2003 | 10:35 AM
amp17757's Avatar
amp17757
I think Ken might have been considering the possibility of a CV joint wearing out, if 4WD. As the joint wears out (especially if the boot has ripped), metal-to-metal contact will start to occur within the joint, causing a clicking sound on hard turns. It will get worse as time goes on. If the clicking is not loud, you can pull the sub-axle, clean the joint out real good, re-grease it, & replace the boot. It will go for awhile, but, most folks who are going to go to all the trouble to pull it AT ALL are going to replace it, unless it's REALLY EXPENSIVE. At least if it fails, you still have the rear wheel drive to get you home.
Old May 6, 2003 | 10:53 AM
tdf138's Avatar
tdf138
Had it in the shop & had the guy check the front end.
Everything was fine but he did find some gravel inside the boot.
Old May 6, 2003 | 10:55 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Have you guys with the noise problems checked to see if your tires are rubbing on something at full turn? Look for wear on the tires and or shiny metal.
