tranny options
Old Nov 30, 2011 | 10:15 AM
koch26's Avatar
koch26
tranny options
i was wondering if i could mate up a zf5 to my 390 and then have a married transfercase. and what mounts and bellhousings and clutch and everything would i need right now i have np435 4 speed. with the divorced. and also i want to do a 12 valve swap in the future and would like to know if it would with a cummins to. thanks i have searched about it and found nothing
Old Nov 30, 2011 | 01:07 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
I don't know if they make an adapter for it. I was originally going to do the same thing. But, I've decided to go with the 351W I robbed along with the ZF-5 and it's transfer case, out of an 89 F-250.
Old Dec 4, 2011 | 08:00 PM
RichS2659's Avatar
RichS2659
Your cheapest way is to use a NVG 4500 and a conversion bellhousing for the FE, as 4500's were used behind 6BT's. When you go to a 6BT, you could use a stock bellhousing. It would be hard to find an adapter for an FE ZF.
Old Dec 5, 2011 | 11:11 PM
ceetwarrior's Avatar
ceetwarrior
+1. As a NV4500 swap owner myself I highly recommend this if you want to stick with a Manual.
Old Dec 8, 2011 | 06:05 PM
Alvin in AZ's Avatar
Alvin in AZ
Be careful which NV4500 you get tho...
QUAD 4 x4 LLP Your 4x4 Experts
Alvin in AZ
n4twz
Oct 5, 2013 03:08 PM
dennisdorrance
31
Jan 6, 2010 12:54 PM
67nukeford
Nov 1, 2009 11:18 AM
Yates73F250
Jan 22, 2005 01:58 AM
