Slow cranking issue
Old Nov 29, 2011 | 09:49 PM
Johnny L's Avatar
Johnny L
Slow cranking issue
Ok so I have been having a slow cranking problem that has gotten worse over the last couple of days and now it's to the point where I can't even come close to starting.
- My batteries are good because I've swapped out 2 spare batteries that I know are good and freshly charged them first. No change.
- I changed the starter out for a spare that I also know is in excellent condition. No change.
- Connections at the batteries are very clean and tight.
I just checked the ground cable that connects the engine block to the battery (next to the fuel lift pump) and it looks pretty rough! I'm hoping that changing that will make the difference.
Old Nov 29, 2011 | 09:50 PM
Johnny L's Avatar
Johnny L
I need to get 25 posts I think to add a picture
Johnny L's Avatar
Johnny L
xxxxxxxxxx
Johnny L's Avatar
Johnny L
zzzzzzzzzzzz
Old Nov 29, 2011 | 09:51 PM
Johnny L's Avatar
Johnny L
xxxxxxxxxxxxxxxxxx
Johnny L's Avatar
Johnny L
xxxxxxxxxxxxxxxxxxxxxx
Johnny L's Avatar
Johnny L
xxxxxxxxxxxxxxxxxxxxxxxxxxx
Old Nov 29, 2011 | 10:02 PM
starmilt's Avatar
starmilt
It takes a lot of juice to spin these motors, What size batteries did you install.
Make sure your grounds where the cables hook to the block are clean and tight.
A lot of the time your hot cable will be swollen under the insulation right at the battery cable, if you cut the insulation and peel it back you will find it green with corrosion.
I have even seen the starter mounting surfaces dirty and corroded enough to not let one spin right.
Old Nov 29, 2011 | 10:04 PM
Johnny L's Avatar
Johnny L
Ok thanks. I tried to post picture but for some reason I am still no allowed to upload. I can't figure out how to delete those messages above either!
Old Nov 29, 2011 | 10:08 PM
43snowcone's Avatar
43snowcone
I had an issue like this with my truck.. Check Both your Hot and your Ground battery Clamps. if they are loose, or old its possible that you may be drawing juice from only one battery.
Old Nov 29, 2011 | 10:12 PM
starmilt's Avatar
starmilt
Sometimes after you get 25 posts, it will be midnight or there abouts before it recognizes them.
Old Nov 30, 2011 | 11:19 PM
Cowman79's Avatar
Cowman79
I had a similar problem with my truck when it was hot. When my truck was cold it would start perfectly and when it was hot it would barely turn over. I ended up getting a new starter which didn't make any difference. The fix for the problem was two new 1025 CCA batteries. I had my old ones tested by a diesel mechanic with a snap on load tester and they tested good, but I haven't had a slow crank since I replaced the batteries. Just my 2 pennies
Old Nov 30, 2011 | 11:58 PM
finitetime's Avatar
finitetime
The wire to the batteries can be bad in coming from either battery or at the starter. It can even be bad inside the lead connector. Shove a voltage meter lead into the battery further-est from the starter. Lay the meter on the hood and crank the motor for several seconds and watch the voltage drop. Repeat the process at the other battery and at the battery. Oh if its at the battery they will both have the same voltage and this test won't work. If one shows a significant drop in voltage you have section of wire to replace. To test the lead connector shove your lead between the battery terminal and the lead connectors and repeat the process. I had one that looked perfect but wouldn't crank till I cut he ends of the battery cable and put $3 cheapo on it. It has been running for years now. Just think if its not the batteries or starter its in the wires!!!! Clean the connections and if that doesn't help find someone who is good with electrical stuff if you aren't.
Old Dec 1, 2011 | 12:00 AM
finitetime's Avatar
finitetime
Cowman I bet your problem is a bad connection somewhere also. More power can always push through the crap in a bad connection somewhere.
Old Dec 1, 2011 | 01:16 AM
Johnny L's Avatar
Johnny L
Thanks for the help guys.
Turns out both the sets of batteries i used were garbage. $300 later i have a pair of 850CCA new batteries. Helped enough to start truck but still slow. Tomorrow im making 2/0 cables brand new. If that doesnt work i suppose both my starters are shot too.
