lossing charge sometimes.please help
Old 11-29-2011, 04:55 PM
joekacker's Avatar
joekacker
joekacker is offline
I was driving this morning and all off a sudden my battery light came on, If Im going under 20 its charges like normal, when I pick up speed like anywhere from 35 and up it drops down and the light comes on? and the heater cuts down to nothing, Is this my alternator or something else?> all battery and grounds are tight. and belt is tight? any ideas? and is the votalge regulator in the alternator or is it a box off the side like the chevys?>
91 150 302
Old 11-29-2011, 06:24 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
The regulator is internal to the alternator. Take the alternator off and have it tested. Still very odd that the faster you go the worse it gets, but stranger things have happened.
Old 11-29-2011, 06:28 PM
droff85's Avatar
droff85
droff85 is offline
My dads 94 would just decide to turn the battery light on but it never really gave us any problems other than that. Eventually the alternator just went out. I would say to have the alternator tested.
Old 11-29-2011, 07:23 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
I actually saw one with a bad regulator that was charging FULL all the time, it would make the light come on when reved up...
Old 11-29-2011, 07:38 PM
joekacker's Avatar
joekacker
thanks boys. I just went for it, and changed the alternator, It used to charge way up in the 15 16 area now its lower, I dont know, All i know is its fixed, now, it may not be chargong up in the top, but its charging. maybe ill throw my group 27 deep cycle in.
thanks again,
Old 11-30-2011, 11:02 AM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
If you were truely charging in the 15~16 volts you were over charging and would boil the battery. High 13's to low 14ish is fine. Deep cycles dont make good starting batteries.
Diverdan0430
06-19-2017 02:30 PM
2danglong
1999 to 2016 Super Duty
15
03-02-2011 01:32 PM
sls985
03-27-2003 07:28 PM
mchild
Electrical Systems/Wiring
09-29-2002 01:29 AM
mike
11-09-1999 02:25 AM
Quick Reply: lossing charge sometimes.please help
