Wierd trams issue...input please
Nov 28, 2011 | 08:41 PM
Well I just went to take off from a stop sign and it was like somebody put it into neutral. Stopped cause I thought I broke a u-joint. I couldn't find anything bro. Put the transmission into reverse went fine. Put it into drive and nothing. Put it into first gear and it takes off and drives fine. So I manually shifted my way home. Anybody have any idea what is causing this issue? Fluid level looks great. Is it dangerous to drive the truck like this? Thank you in advance.
Nov 28, 2011 | 09:15 PM
A one way clutch failed. You won't hurt anything by driving it like it is. A rebuild is required to fix this.
Nov 28, 2011 | 09:18 PM
Quote:
Originally Posted by
Mark Kovalsky
Glad to hear this won't hurt anything. Any idea of cause? Any idea of cost to rebuild this?
Nov 28, 2011 | 09:22 PM
BTS or JW. I will go out pretty soon. Mine ran good for a while but then stopped all together. Good luck with yours. Also a OEM HD would be good to.
Chet
Nov 28, 2011 | 09:24 PM
Bonanza35
Chet
That was my next question. What is a good aftermarket so this doesn't happen again?
Nov 28, 2011 | 09:52 PM
Also can the sprag clutch be just replaced without pulling the whole trans or is it going to have to be totally disassembled?
Nov 29, 2011 | 05:22 AM
robinsonpowerstroke
Both Brian's Truck Shop and John Wood make good aftermarket transmissions from what I hear.
robinsonpowerstroke
You need to pull the trans and pull it just about all the way apart to get to this one way clutch.
Nov 29, 2011 | 06:30 AM
Mark Kovalsky
Ok so do BTS and JW make their own one way clutch or do they buy an aftermarket and just bolt it in?
Nov 29, 2011 | 03:21 PM
They do make alot of there own parts. Can't say forsure if they make this one. Give either guy a call and they will talk to you for free.
Chet
Nov 29, 2011 | 04:51 PM
One way clutches are fairly complicated to make. I don't know for sure, but I'll bet they buy theirs.
Nov 29, 2011 | 07:12 PM
Mark Kovalsky
I will definitely will give them a call and hopefully they will tell me the brand they use.
pb0000
Mar 1, 2019 06:34 PM
BaitsandBullets
29
Jul 9, 2018 04:21 PM
pstroke97
Aug 18, 2015 10:15 PM
culprit138411
2004 - 2008 F150
Jun 8, 2010 05:41 PM
RaceExplorer
Apr 9, 2003 07:44 PM
