How hard / what needed to replace marker bulb?
Old Nov 28, 2011 | 07:59 PM
Rushmore X's Avatar
Rushmore X
Did a search on Google and the forum and didn't come up with anything helpfull. thanks
Old Nov 30, 2011 | 02:14 AM
robert_l_ross's Avatar
robert_l_ross
If you are unlucky like I was, your bumper may be on too high to get a screwdriver in yo the two screws under the turn signal assembly. If it is, you need to lower the bumper a bit and you will see them.
Open hood, disconnect headlight wiring connector, remove headlight housing (three adjuster screws all the way out and pull the headlit assembly out towards the front).
Unscrew two Lowe turn signal screws, pull turn signal forward and remove side marker light socket and replace.
Reverse steps.
Old Nov 30, 2011 | 06:44 AM
Rushmore X's Avatar
Rushmore X
Thanks, I finally found it in the manual. Like you said, it was hard to see the two lower bolts...
EMD_DRIVER
Dec 14, 2012 02:48 PM
878ranger878
May 2, 2011 08:29 PM
dagren99
Mar 14, 2011 05:44 PM
harley3348
Feb 21, 2011 12:08 PM
Cool1996
General Automotive Discussion
Feb 13, 2005 07:19 AM
