Another Tailgate crack
Old Nov 28, 2011 | 07:15 PM
true blue's Avatar
true blue
My tailgate / Liftgate panel cracked today. I join all the other explorer owners who have experienced the same cosmetic flaw.
I have included instructions from Ford on this for anyone else that may want to attempt this repair themselves. I will replace soon and I will show pictures of the process soon.
Old Nov 28, 2011 | 08:46 PM
turborich's Avatar
turborich
Mine is not yet cracked however I notice that at least 75% of the Explorers I see driving on the streets are cracked, usually on the left side of the Ford emblem.
What causes this? Does it just crack for no reason or is it from the owner applying pressure to this area when closing the rear hatch?
Old Nov 28, 2011 | 10:54 PM
true blue's Avatar
true blue
I am guessing fatigue life has been met through expansion and contraction of the plastic panel. I can assure you that we have not slammed or pressed the panel harshly. Like you I saw many others cracked and I was extra careful. Notice that after 2005 there was a re-design?
Old Nov 28, 2011 | 11:22 PM
turborich's Avatar
turborich
Yes, I have seen that, No more plastic piece, just metal to the window.
These Explorers seem to have quite a few flaws. I'm having second thoughts about owning one. This back panel is the least of my worries.
Old Nov 29, 2011 | 05:22 AM
true blue's Avatar
true blue
My explorer has been a good vehicle for the most part. I have had on going transmission annoyances but nothing that seems to affect reliability.
Old Nov 29, 2011 | 11:48 PM
old farmer's Avatar
old farmer
The panel on my Aviator cracked, was replaced and then cracked the following winter.
It happened when I closed the glass section of the tailgate and pushed on the panel section while closing in cold weather.
Now I push on the wiper motor, or the glass. No cracks yet.
When closing the whole tailgate, I push on the steel section near the licence plate.
I totally avoid pushing on the plastic panel.
If it ever cracks again I'm going to fill it with JBweld, sand and paint it.
Old Sep 21, 2015 | 03:10 PM
jtab4994's Avatar
jtab4994
Bumping up an old thread.
The last poster said he was going to try JB Weld if his cracks again. Does anyone know if that would work? Anyone have a DIY solution other than replacing the plastic piece, which could then crack again? Any OEM or after-market replacements that use a more durable type of plastic?
We have a 2005 Explorer, and after years of watching others' tailgates crack, ours cracked in July 2014. Wife is now making it an issue and agitating for a fix, and I'd like to avoid buying her a new vehicle if at all possible!
Old Sep 21, 2015 | 03:26 PM
Tedster9's Avatar
Tedster9
JB-Weld is pretty good stuff actually. There might be a better product for your application, maybe. It can be sanded, drilled, machined etc. and handles high temps and low temps, oils and fuel, and is nonconductive. When I was in the .mil we had a pretty good selection of similar epoxies, even "5 Minute" cots purchases in the little packets. The strongest as I recall though, was popularly called "the pink sh_t" because that was the color.
Old Sep 21, 2015 | 07:15 PM
shorod's Avatar
shorod
I wonder if that pink stuff you refer to is A-12. Depending on the mix ratio though, A-12 has more of a terracotta color.
-Rod
Old Sep 21, 2015 | 08:24 PM
Tedster9's Avatar
Tedster9
Can't remember anymore, but the popular names. It was bubble gum pink. There was also other materials that had slang names, called "Elephant snot" and "Peanut butter". I think the latter referred to a type of lubriplate.
Old Sep 22, 2015 | 08:11 AM
IIGood's Avatar
IIGood
I thought the initial problem behind the cracking of the panel was the adhesive that was used to secure the plastic panel to the gate...it didn't allow for proper flexing of the panel, thus causing the cracking. The fix was a different adhesive which allowed for the flex.
If that's the case, then I'd think JB Weld would just fill the crack in the mean time but still wouldn't solve the overall issue...
Binkowski
Dec 2, 2016 10:22 AM
1997fordf350
May 9, 2013 06:45 PM
Heavenword1
20
Mar 13, 2013 08:02 PM
crosbo
Jun 25, 2010 12:15 AM
SHOpar
19
Nov 6, 2009 02:02 AM
