Turbo Gasket
Old Nov 27, 2011 | 09:35 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Turbo Gasket
Is there a gasket between the turbo and the outlet elbow with the wastegate in it?
It looks like it was just carbon but I can't tell for sure.
Factory '94 Turbo IDI.
Old Nov 27, 2011 | 09:36 PM
typefour's Avatar
typefour
no gasket.
Old Nov 27, 2011 | 09:46 PM
Otahyoni's Avatar
Otahyoni
Why don't they use a gasket? My banks kit calls for gaskets (long missing) on either side of the heat sheild.
Old Nov 27, 2011 | 09:55 PM
Aune163rd's Avatar
Aune163rd
There is no gasket at the wastegate, its probably just carbon buildup....although why would you have carbon buildup on your wastegate???
Old Nov 27, 2011 | 10:03 PM
Dodge/Cummins
Black diesel exhaust. Soot is probably more correct.
I'm going to use some copper gasket spray on it anyway when I reassemble it.
I wish ATS still made the 3" elbow/outlet and down pipe.
Old Nov 27, 2011 | 10:52 PM
starmilt's Avatar
starmilt
It seems like I read sometime in the last few days, that typefour does some kind of upgrade on them. It might be worth your while to check with him.
Old Nov 27, 2011 | 11:20 PM
1BadB2's Avatar
1BadB2
I can make your stock one into a 3" outlet and you can use a banks DP or custom 3" DP with it.
I have done several, for myself and a few members. At a much cheaper price than ATS was getting for them too, with a better sealing method as well.
Just food for thought.
Hawkeye2
Mar 31, 2019 04:56 PM
85Supclub
Jun 5, 2017 04:34 PM
bcaughhorn
15
Jun 6, 2012 05:27 PM
turbo diesel fan
Apr 20, 2012 10:54 PM
pontichev
Feb 10, 2009 07:06 PM
