1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 F250 no rear sway bar?
Old 11-27-2011, 12:44 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
I've recently notice that my truck is so far the only one I've seen with no rear sway bar. I bought it new and thought all these trucks come standard with them. Is this not the case? If some came without then why and was it an option or something? My truck doesn't handle nearly as well as my friends and were both factory set up even down to tire size. Any thoughts on this? Thanks.
Old 11-27-2011, 01:57 PM
Rongold's Avatar
Rongold
Rongold is offline
REAR SWAY BAR
I think that only trucks ordered with the camper package had the sway bar. No other suspension package included the sway bar.
RON
Old 11-27-2011, 02:06 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
His truck does not have camper package as I just checked.
Old 11-27-2011, 02:36 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
rear sway bar was a option..
dont remember if it was a solo option or part of a package thou.
Old 11-27-2011, 02:45 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
I too thought it was only part of camper package
Old 11-27-2011, 03:04 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
I have the sway bar. I don't have the camper package though. I have a stabilizer package whatever that is.
Old 11-27-2011, 03:40 PM
LMS Residential's Avatar
LMS Residential
LMS Residential is offline
Get a Hellwig. Full 1 1/4" bar, easy to install once you throw away thier directions, cost comparable to factory bar but with better hardware and poly bushings.
Hellwig - Load and Sway Control Products
Old 11-27-2011, 03:43 PM
Quad Racer's Avatar
Quad Racer
Yeah the sway bar on my truck looks like it belongs on a Ranger. It appears to measure about 3/4" maybe.
Old 11-27-2011, 03:49 PM
LMS Residential
I went from no bar to the hellwig and the difference is amazing. No sway at all even when towing heavy. With the right tire/wheel combo (-12mm offset works nice on 2wd SDs) and a bilstein steering stabilizer with KYB gas a justs @ ea corner, this thing sticks like glue...and lasts, did these mods about 65k ago.
Old 11-27-2011, 05:55 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
I went with the Hellwig Big Wig and there is a huge difference in handling even with a load.
Old 11-27-2011, 06:07 PM
jmiley's Avatar
jmiley
jmiley is offline
The camper package is more than just the rear sway bar.
Old 11-27-2011, 06:16 PM
LMS Residential
Seems like a lot for 160 bucks................
471 Camper Package - $160
Extra heavy service front springs; Rear suspension with stabilizer bar; Slide-in camper certification; Rear auxiliary springs; Excludes: [66D] Pickup Box Delete (Fleet) And [67H] Heavy Service Suspension Package
Read more: 2012 Ford F250 Packages & Options | New
Old 11-27-2011, 07:13 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
So what all is in the stabilizer package? Also why would you not want one of these? Seems like it should be standard to me. Thanks for everyones post so far.
Old 11-27-2011, 07:59 PM
senix's Avatar
senix
senix is online now
Received 1,430 Likes on 1,023 Posts
I don't have the camper package or the sway bar either. Don't feel as I need it though either.
Old 11-27-2011, 08:07 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
Ok Senix thanks. So why would anyone not want better handling? Not speaking to you specifically but I'm surprised why ford would leave this off. Honestly when I bought my truck I just figured big trucks drove that way. I mean I had to drive alot slower in turns etc. Then Im in my buddies with factory sway bar and I can't believe how much better his truck handles on curvey roads. I'm guessing towing heavy loads will be better too. Anyway thanks for everyones post and I'm going to buy a hellwig this week.
Quick Reply: 2008 F250 no rear sway bar?
