clatter problems
Old Nov 27, 2011 | 09:52 AM
hotrod1979ford's Avatar
hotrod1979ford
clatter problems
I was wondering if there's anyone out there who can tell me if the clatter I hear at 45 mph or 2000 rpm is cam bearings bad or if cam bearings would even clatter that way. I can say my oil pressure is low after it warms up. By the way, its a 400M. Someone please help me and tell me whats up.
Old Nov 27, 2011 | 11:27 AM
4x4 Bart's Avatar
4x4 Bart
I don't think bad cam bearings would clatter.
Bad cam bearings will give you low oil pressure but so will rod and main bearings.
I would look closely at excessively worn or broken rocker arms.
Old Nov 27, 2011 | 04:31 PM
hotrod1979ford
I just changed all the push rods. I know none of the rockers are broke. But I suppose they could be worn. The bad rods and mains make sense to. When I built it, I put a 3in magenet in the oil pan. Which was covered in metal dust when I recently changed the oil pump to. I will change the bearings to. The only thing is that its not a constant knock like that would be. But its worth looking at. Thanks for the info.
stormchaser70
Jul 11, 2009 03:50 PM
cfrives3
29
Apr 18, 2007 07:16 PM
mattsf250
Dec 9, 2003 06:07 PM
screwy
Sep 4, 2003 10:11 PM
fishin1976
Oil & Lubrication
Jul 20, 2003 01:15 AM
