Start Up Surge
Old Nov 28, 2011 | 06:05 PM
madpogue's Avatar
madpogue
Originally Posted by Action4478
If it is truly the "romps" at start up it is usually an electrical signal issue . May be due to the ICP sensor or wire as I said , or a slow to respond IPR also .. The PCM can't see fuel pressure . SLow up and down idle can be from something as simple as a plugged FPR screen ...
Ah yes, good point; one of the nuances of a computer-controlled engine with a mechanical fuel system....
Old Nov 29, 2011 | 04:01 AM
Chris56ford's Avatar
Chris56ford
lost
Originally Posted by madpogue
That's not just your humble opinion, that's how it works. Glow plugs cycling on and of is NOT, contrary to the previous post, normal! They're programmed to go on, stay on for a few seconds to up to two minutes, then shut off. If they're cycling on and off, that's probably because the glow plugs are pulling too much current, and overloading the relay, and it's cutting itself out.
But in the OP's case, if it's only romping 4-5 times, it's probably not this anyway. Sounds more like a fuel pressure / HP oil pressure thing. Might be worth checking the level of the HPOP reservoir and/or the fuel bowl before a startup sometime.
Yep, I should not have opened my mouth, I apologize.
tater3000
Sep 29, 2018 12:08 PM
Cmg66999
Feb 28, 2016 12:48 PM
ALL BOY
19
Dec 27, 2010 06:49 AM
high ho silver
Sep 30, 2004 06:57 PM
zirius
Sep 7, 2004 02:30 PM
