reverse light switch
Old Nov 26, 2011 | 07:04 PM
oldmerc's Avatar
oldmerc
oldmerc
Hello
what is the best way to install a back up light switch
in a 49 F3 with a top loaded trany.
Allan
Old Nov 26, 2011 | 09:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Short of some machine work to create a location for a switch on the shifter rail for Rev, I don't see a way.
Old Nov 26, 2011 | 10:11 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I occasionally see aftermarket kits on eBay for sale.If I'm not mistaken,some of the earliest examples included a manual on/off switch.That's an example of low-tech, appropriate technology.
I found one that would be period correct,you'd need to provide a switch.Looks pretty cool:
http://www.ebay.com/itm/1940-s-1950-...#ht_629wt_1344
Here's another:
http://www.ebay.com/itm/Vintage-nos-...#ht_500wt_1361
Old Nov 26, 2011 | 10:41 PM
52 Merc's Avatar
52 Merc
Back in the 60's, Ford used a simple plunger switch that the reverse shifter arm would contact when engaging reverse gear. Granted, they are external linkage, but you could probably rig up something on the top of the trans that would do the same thing using the shifter lever to push it in and actuate the lights.
Old Nov 26, 2011 | 11:21 PM
GB SISSON's Avatar
GB SISSON
If you go with the ibuzzard switch you should have a dash light along with it. One night I got pulled over for a white light shining to the rear when I forgot to turn it off. I have some kind of generic mechanical hot rod brake light switch that came with a bunch of parts once and I thought about setting it up on top of my fridge 4 spd. I built a rear bumper last week and mounted a backup light under it but so far it's just a decoration, so this is a timely thread..
Old Nov 27, 2011 | 08:09 AM
oldmerc's Avatar
oldmerc
oldmerc
Thanks everyone,some real good ideas ,I think I will use a combination.
Since Alberta law says at least one backup light must be automatic with the engagement of reverse gear,I think I will do a little in house machining.
Allan
Old Nov 27, 2011 | 08:46 AM
38 coupe's Avatar
38 coupe
Does the Alberta law require this on all vehicles? Here in the USA, our old trucks (and cars) are grandfathered in. I am not required to have any safety equipment that wasn't on the truck new. In addition, once added, some safety equipment, like seat belts, cannot legally be removed.
toofazt
13
Nov 4, 2016 03:58 PM
andrewbragg
May 16, 2013 09:31 PM
Boba Fett
Jan 13, 2013 05:21 PM
aintskeered
Feb 3, 2012 09:59 AM
71F100/390
Jan 12, 2006 08:36 PM
