Head gasket install
Old Nov 26, 2011 | 06:46 PM
dieselaholic's Avatar
dieselaholic
Head gasket install
Well im following the book to a T and it said to coat head bolts with a coat of oil. Well i got the bolts torqed i noticed some oil coming from the gasket on the bottom side. Im not sure what i should do. Should i buy another set of gaskets and install w/o oil. do you think they will eveer seal?
Old Nov 26, 2011 | 07:01 PM
starmilt's Avatar
starmilt
I have always used just a light film of oil on them.
Old Nov 26, 2011 | 08:42 PM
typefour's Avatar
typefour
they should be fine it will squeeze out.
Old Nov 26, 2011 | 08:59 PM
starmilt's Avatar
starmilt
I have always used either or something prior to installing headgaskets to make sure there is no oil residue on the surfaces, but it might be all right, I might would get it good and warm and retorque them.
Old Nov 27, 2011 | 01:34 AM
1BadB2's Avatar
1BadB2
did you stud it?
Old Nov 27, 2011 | 08:30 PM
dieselaholic
Thanks for the replys but i went ahead and pulled the head back off amd im glad i did. It had enough oil on it i dont think it would have sealed correctly.
No i didnt stud it. Is there a reason to stud a 7.3 since it already has 1/2 head bolts?
From what i learned install bolts relativly dry.
1Austin112
Mar 31, 2015 03:55 PM
007bronco
May 5, 2014 04:03 PM
F-250 restorer
Dec 17, 2011 10:34 AM
orange_x_crush
Sep 6, 2008 04:00 PM
