OBDII problem
Old Nov 26, 2011 | 02:43 PM
wilefish's Avatar
wilefish
OBDII problem
Hello all, I have a 2004 crewcab F-250 6.0 PSD manual transmission 4x4. My trouble is my obd2 doesnt seem to notice the key being turned on.If i try to change programs with my superchips tuner it just keeps telling me to turn key on. If i plug in my scangaugeII. It just doesnt read the scangauge just shows connecting?I have checked the fuse it is good.i also tried disconnecting the batteries and leaving disconnected for an hour.I dont see any wires chafed or missing. any help would be greatly appreciated
Old Nov 26, 2011 | 03:13 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
The only thing I would have had you check was the fuse. Not sure what else you could check.
Power port fuse, or cigarette fuse?
Old Nov 26, 2011 | 03:20 PM
Rebuild101's Avatar
Rebuild101
I had a problem on my 05 batts kept going dead. The chip tooh out the alternator through the engin light on took the chip off changed altinator and have had no problems. Unhook the chip and see what happens
Old Nov 26, 2011 | 03:45 PM
wilefish's Avatar
wilefish
obdII
the fuse in the fuse panel is good. truck runs and drives fine it just doesnt read the ignition being turned on in the obdII. scan gauge just shows connecting and then shuts down.the scan gauge does work on other vehicles just not on this truck. if i try to reprogram with my tuner it just stalls when it tells you to turn on ignition as if it doesnt read the key being turned on.
lostislandguy
15
Mar 8, 2023 01:04 PM
Waterwise
Jul 18, 2017 12:40 AM
imper
Nov 21, 2010 03:14 PM
V10_Cougar
Modular V10 (6.8l)
Jan 6, 2009 12:15 PM
brians2000
Electrical Systems/Wiring
Nov 13, 2006 08:40 AM
