69 F350 Bump Side Crew Cab Restoration
Old 10-30-2014, 05:09 AM
f100today's Avatar
f100today
f100today is offline
This thing is going to be so cool. I went to home depot and bought paint stripper for $22 per gallon. it makes a huge mess but it works. Once it gets the paint somewhat off to mostly off after a few applications with a brush, I washed it off and then used a orbital sander to get down to the metal. It is messy and time consuming but saves some $. My guess is you would have about $250 in materials.
So I am a little confused? Are you doing a 12v 6bt now? or a 4BT
  #122
Old 10-30-2014, 05:39 AM
brobrad's Avatar
brobrad
brobrad is offline
I did the 4bt already. It went in my 03 F150 supercrew 2wd. it's the family vehicle burning veg everyday. It has saved a bunch of fuel money.
I've considered sanding and the stripper approach, but the guy with 3 decades of experience said that a blasted vehicle gets much better adhesion than does the sanded approach because the metal becomes so smooth with sanding whereas the blasted surface is much more textured. Just weighing it all out. Thanks
  #123
Old 10-30-2014, 10:02 AM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
Sounds like your talking to the right guy!
Yes the blasting does give the paint better surface to stick to.
  #124
Old 10-31-2014, 08:29 AM
brobrad's Avatar
brobrad
brobrad is offline
Looks like that'll be the route I go. I called the dipper back yesterday and He said that the EPA had gotten so hard on them that they didn't want to deal with it anymore. He and his brother are both in their 60's and no one wants to buy the company being in the hood. They are finishing their back log and closing that side of the business.
  #125
Old 11-03-2014, 06:33 PM
brobrad's Avatar
brobrad
brobrad is offline
Score ( i think)
I bought a built 47RH yesterday and I'm having it shipped tomorrow. Supposed to be the real deal and the price is good. Hoping to sell my 4x4 47rh to recoup part of my money.
  #126
Old 01-07-2015, 07:57 AM
brobrad's Avatar
brobrad
brobrad is offline
small update
I have been slowly collecting parts to hopefully get a little more work done. I've been working on a Jeep project with one of my sons and getting in a little hunting time with all three of the kids so "work" time has been non-existent. BUT, I have no regrets. The ole 69 should still be around when they've all moved on to their own pursuit of God's will for their life.
Anyway, here's the latest:
I picked up a 12V P-pumped motor and sold my VE motor for the same money I have in the P-pumped motor. It has only 75K original miles. I pulled pan and cross hatching is visible on all cylinders from the bottom. The pump was untouched. Came out of a totaled 1-ton.
I picked up a few parts to pep up the P-pumped motor. I have a 351CW turbo to add to her so I grabbed a boost control elbow since the turbo is waste gated at 25 psi, I have some 60# valve springs for the 4000 RPM governor spring I picked up and a #4 fuel plate from TST products. I hope to crank engine on the stand soon and add the mods a little later on.
BTW- my built 47RH came it and is sitting on the floor waiting on a clean up and inspection- supposedly only at 25-30k on it. Has Billet imput, triple disc and valve body mods.
  #127
Old 01-08-2015, 09:15 AM
highntight's Avatar
highntight
highntight is offline
Thats all you can do sometimes... Its going to be worth it in the end..
  #128
Old 04-17-2016, 01:23 PM
268Fords's Avatar
268Fords
268Fords is offline
I don't know where you're located, but I have a factory sliding window with the old gasket for a 67'-72' that I've had sitting in the garage for years. I sold my 68' 4wd short box a few years back and have no use for it now. I'm in Napa, ca.
  #129
Old 04-17-2016, 01:24 PM
268Fords's Avatar
268Fords
268Fords is offline
It's yours if you want it.
  #130
Old 04-17-2016, 05:30 PM
brobrad's Avatar
brobrad
brobrad is offline
Man, thanks for the offer. I'm actually parting with the whole project. My kids are 20, 18, and 16. I'm trying to get them in/through college and spend as much time with them as i can. I don't have the $5-7K or 300 hours to get it where i want it. Perhaps someone else can benefit from your generosity.
  #131
Old 04-18-2016, 03:08 PM
268Fords's Avatar
268Fords
268Fords is offline
Ok. I just don't want to throw it away.
  #132
Old 09-19-2016, 07:18 AM
brobrad's Avatar
brobrad
brobrad is offline
This thread is officially done. I couldn't afford to even get close to finishing due to funds. I traded a portion of the swap for an 04 f250 swb cc on an 05 fx4 frame. Thanks for all the help along the way. I'm putting my 12v and 47rh in the newer ford.
  #133
Old 09-21-2016, 10:40 AM
highntight's Avatar
highntight
sry to hear that bud.... I know how it goes for sure... But at least you got another project to keep you mind working, and sounds like the new project will be a little better for you at this point in time, good luck sir...
  #134
Old 09-21-2016, 10:43 AM
brobrad's Avatar
brobrad
brobrad is offline
Agreed! It's painful, but its reality.
  #135
Old 09-21-2016, 12:02 PM
Trucker_Jo's Avatar
Trucker_Jo
Trucker_Jo is offline
Sorry to hear you have to part with the ole CC! So where is it at now/ for sale?
Quick Reply: 69 F350 Bump Side Crew Cab Restoration
