What is this hole?
Old Nov 25, 2011 | 08:07 PM
85RanchTruck's Avatar
85RanchTruck
What is this hole?
I have an 85 F250 with the 4.9L In line 6 cyl. 302. I was recently driving at hiway speeds when it started to feel like I had an exhaust leak. The engine ran rough, I lost a little power at low RPMs, and it also sounded like an exhaust leak.
When I started to take things apart to replace the exhaust and intake manifold gasket, I noticed a hole on the front side of the manifold near where it bends to meet the exhaust pipe. This hole is not threaded and is a clean cut round hole, but I cannot figure out what used to be in it. When I cover the hole, all the problems cease.
What goes in there? is it important?
Thanks.
Jesse
Old Nov 25, 2011 | 09:50 PM
mblayton's Avatar
mblayton
I take it that you mean you have the 302 not the 6 cyl. and being a 85 it would be carbed, so that hole you mention is more than likely for a heat rise tube to the carb for your choke.
4.9L = 300 c.i.
5.0L = 302 c.i.
Hope this helps.
Old Nov 25, 2011 | 11:24 PM
EffoneHunded's Avatar
EffoneHunded
here is a 4.9l 300 6cyl exhaust and intake
click to enlarge
Old Nov 25, 2011 | 11:28 PM
Eightyfive Flareside's Avatar
there should be a thick steal pipe that threads into there if i remember correctly, its been so long since i had a 300...
Old Nov 25, 2011 | 11:55 PM
bruno2's Avatar
bruno2
If you dont have the pipe anymore I bet a pipe plug would thread into it to seal it up.
Old Nov 26, 2011 | 12:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Eightyfive Flareside
there should be a thick steel pipe that threads into there if i remember correctly, its been so long since i had a 300...
1984/86 F150/350, Bronco & Econoline 4.9L (300 I-6):
E4TZ-9D477-A .. Tube-EGR Valve to Exhaust Manifold / Obsolete
FORD PARTS ONLY in Bayamon Puerto Rico has ONE = 787-786-9180 / No other Ford Dealer or obsolete parts vendor has any.
2) 387285-S36 .. Connector Fitting-EGR Tube to Exhaust Manifold and to EGR Spacer Plate / Obsolete
3/4" -14 male pipe thread / 1 13/16" female pipe thread / 7/8" tube.
Dozens are available NOS from Ford Dealers/obsolete parts vendors.
Old Nov 26, 2011 | 06:37 AM
Archion's Avatar
Archion
Veteran: Marine Corps
[quote=85RanchTruck;11079497 I noticed a hole on the front side of the manifold near where it bends to meet the exhaust pipe. This hole is not threaded and is a clean cut round hole, Jesse[/quote]
If the threads are gone, then you will need a replacement manifold, then you can plug it off.
Old Nov 26, 2011 | 03:06 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
4.9L = 300 c.i.
5.0L = 302 c.i.
Hope this helps.
If you do a mathmatical problem, technically you are both correct as the 300 AND 302 CID averages out to 4.9L. Ford called the 302 a 5.0L to eliminate confusion.
shawnmk
Jun 28, 2018 07:28 PM
ftrk66
Sep 25, 2011 06:14 PM
Monarchfootbal77
Exhaust Systems
Dec 31, 2006 07:56 PM
big_daddy_velvet
1978 - 1996 Big Bronco
Apr 1, 2003 11:52 AM
pracklam
May 11, 2001 07:35 PM
