Bed Mat
Old Nov 25, 2011 | 12:04 PM
ch803's Avatar
ch803
Bed Mat
Does anyone know of where I can find a truck bed mat that will have an exact fit for a 1965 Ford F100 Short Bed?
Old Nov 25, 2011 | 04:23 PM
Broomfieldbum's Avatar
Broomfieldbum
I cannot tell you for certain, but I can tell you that the upper dimensions of the bed are the same 1965 to 1979. I bought a 1979 tonneau cover and it fits my 1966 perfectly. I would find a 1979, and measure the bed.
Old Nov 25, 2011 | 04:53 PM
ch803's Avatar
ch803
Thanks for the information I will do that.
Old Nov 25, 2011 | 05:28 PM
ch803's Avatar
ch803
Actually where did you get the tonneau cover from?
Old Nov 25, 2011 | 05:43 PM
Broomfieldbum
I got it from Auto Anything.com. I had to get the part number from Extang. They make I believe 3 models that fit. I bought the Full Tilt so my tonneau opens like a hood.
Old Mar 5, 2016 | 10:39 AM
Kodiak17's Avatar
Kodiak17
4wd Low
Did you ever find a bed mat to fit your 1965 Ford F100 Short Bed? I am looking for one for mine.
Old Mar 5, 2016 | 10:56 AM
scottlathrop's Avatar
scottlathrop
Just if you didn't know, the post you are referencing is 5 years old.
There are many suppliers that I think you know about like Carpenter, LMC etc. I don't have one so I can't vouch for the fit. You may get an answer from someone, however if you did not just saying
- it is an old post and they may not be here anymore.
Old Mar 5, 2016 | 12:01 PM
Kodiak17's Avatar
Kodiak17
4wd Low
Thanks. Probably should start a new post.
Old Mar 6, 2016 | 11:15 AM
Broomfieldbum
Kodiak,
You might check for one for a late 1970's F100. The beds are exactly the same size
Another option would be to look at Raptor Liner. It is a Do it Yourself bedliner. The kits I found were about $110 a piece, and it includes the spraygun. I have heard that they are a little thin if you only buy one kit. Raptor seems to acknowledge this because they started selling just the Material parts. So buy one kit and 1 package of Spray Material, and you could get it done by yourself. I also looked into masking tape that has a wire in one side so you can get that over the rail look with a sharp edge.
Old Mar 6, 2016 | 04:08 PM
Kodiak17's Avatar
Kodiak17
4wd Low
Originally Posted by Broomfieldbum
Kodiak,
Hi, Thanks!
Kodiak17
Old Mar 6, 2016 | 04:09 PM
Kodiak17's Avatar
Kodiak17
4wd Low
Hi,
Thanks for the help!
Kodiak17
Old Mar 6, 2016 | 05:01 PM
leonharu's Avatar
leonharu
Try J.C. Whitney.They have one "cut to fit".Part # 339989,55"W and 79"L
Old Mar 8, 2016 | 11:48 PM
hoss73ford's Avatar
hoss73ford
The mats will fit from front to end but the wheel wells on 1965-66, 67-72 and 73-79 are completely different,
Old Mar 8, 2016 | 11:49 PM
hoss73ford's Avatar
hoss73ford
I found a mat at my local Tractor Supply, so I'm going to cut it to fit.
sodly
May 15, 2012 04:54 PM
underh2o2long
19
Mar 28, 2006 04:50 PM
pullin_it
Nov 15, 2002 07:40 PM
comet
Oct 15, 2002 01:15 AM
