Catalytic Converter
Old Nov 24, 2011 | 07:08 PM
dezertdirt's Avatar
dezertdirt
Catalytic Converter
I've got a 1991 F250 with the 4.9L 6. I originally bought the truck when I lived in California, but now live in Oregon. Its come time for a new cat. Does anyone know if I have to use the California Cat or if it will screw up the computer if I go with a 49-state cat. The 49 state is a few hundred bucks cheaper, at least from magnaflow. Thanks
Old Nov 24, 2011 | 08:12 PM
octaneforce's Avatar
octaneforce
just gut the cat you have now, or replace it with a straight pipe. much cheaper solution. on my 92 there are two cats (well, there used to be). the one downstream (closest to the tail pipe) will not affect the computer if removed because there is no oxygen sensor after it.
Old Nov 24, 2011 | 08:27 PM
dezertdirt's Avatar
dezertdirt
Octane, I have 2 cats as well. I assumed it was a California thing since the replacement shows two cats for CA and only one for 49-state. Can I gut both cats and still be fine with the O2 sensor and computer?
Old Nov 24, 2011 | 08:48 PM
IowanStraight6's Avatar
IowanStraight6
Should be just fine since that third o2 sensor is where the y pipes come together
Old Nov 24, 2011 | 08:56 PM
Conanski's Avatar
Conanski
There is no downstream O2 sensors on trucks built before 1996, most 50 state and Canadian trucks have a single upstream while MAF Cali spec trucks have two upstream sensors, but because these are all upstream it really doesn't matter what type and number of cats a truck has as they have no effect on engine operation.
I-6 Addict
Feb 13, 2012 03:32 PM
m8094538
Feb 23, 2010 12:33 PM
FordF350Baby
Exhaust Systems
Apr 29, 2008 01:21 PM
Ben34
1997 - 2003 F150
May 7, 2006 06:41 AM
p521us
Exhaust Systems
Feb 5, 2005 09:08 AM
