What is your setup/Dream setup???
Old Nov 23, 2011 | 09:17 PM
JoeDaf's Avatar
JoeDaf
What kind of setups do you guys have?
Like cams, valve sizes, pistons valve spring intake etc etc.
Also include you dream engine if desired id like to get ideas for my possible upcoming engine build.
Thanks Joe
Old Nov 24, 2011 | 12:43 AM
Col Flashman's Avatar
Col Flashman
Built '65 series 300c.i. (around 312c.i. now) I-6 w/ 300 H.P. @ 4600 rpm & 400 F.T.P. @ 3200 rpm w/ a 9.5-1 C.R.
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
Crane Gold Race Roller rockers
ARP Main Stud Kit, Rocker Studs,
Fisher International Ballancer
Bore 4.060
Power Hone 4.060
Mild P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser DP Intake
Holley 450 Economaster
S.S. Borla 2 into 2 Header
8' of 3" tubes attached to Flowmaster 50's
4 Core Desert Radiator mated w/ the Original Radiator Housing
2 1,200 CPU Electric Fans, on @ 180*, off @ 170* mounted diaginally
Mallory Electronic Ignition Distributor
Old Nov 24, 2011 | 09:15 AM
Harte3's Avatar
Harte3
That is THE dream machine
Old Nov 24, 2011 | 09:19 AM
JoeDaf's Avatar
JoeDaf
I want one of those motors.
Old Nov 24, 2011 | 04:18 PM
Harte3's Avatar
Harte3
Put your money where your "want" is and you have it.
Old Nov 24, 2011 | 04:44 PM
JoeDaf's Avatar
JoeDaf
Yea got to save for that. I'm going to estimate that build at about 8 grand do you think I'm close col?
Old Nov 24, 2011 | 05:49 PM
Col Flashman
JMS Racing Engines only charged me $3436.00 for my build.
It would've been a tick less costly, but they did a certain amount of hand work.
Only because I didn't complete my research & didn't find some off the shelf parts that would've saved that cost in hand work.
Old Nov 24, 2011 | 05:56 PM
JoeDaf's Avatar
JoeDaf
Wow I was way off I must admit that price sound good. Is JMS online or is that a local company near you?
Old Nov 24, 2011 | 07:38 PM
Col Flashman
Local to me, San Gabriel Valley, El Monte Ca.
JMS Racing Engines
Old Nov 25, 2011 | 06:12 AM
eriksf250's Avatar
eriksf250
my dream setup would be a fuel injected twin turbo 300.
Forged pistons
forged rods
ARP rocker and head studs
roller cam w/ roller lifter and roller rockers
fully ported intake and exhaust w/ cleaned up bowls
1.94/1.60 valves
clifford 4v intake set up for the massfloefi.com's mass air fuel injection
custom made headers for 2 T3 turbos off a 2.3 turbo coupe Thunderbird
14lbs of boost
intercooler from a powerstroke
I'd have this in an F-150 backed by a T-56 Viper spec 6-speed and a built 9" w/ 3.55s or 3.73s.
Old Nov 25, 2011 | 02:04 PM
Col Flashman
Forged pistons
forged rods
1.94/1.60 valves
14lbs of boost
Looks good, but Minimal P&Ping is the Best option. Because if to much P&Ping is done, you loose the benefit of P&Ping the 300 in the first place.
Old Nov 25, 2011 | 06:02 PM
eriksf250's Avatar
eriksf250
then i will just do it to the intake and not the exhaust, that way i keep the exhaust pressure there to help spool the turbos quicker
Old Nov 27, 2011 | 08:22 AM
Rockaholic's Avatar
Rockaholic
The T-56 bolts rights up to the 300? Thought they didn't have a 6 speed that fit this beast...
Old Nov 27, 2011 | 10:33 AM
Harte3's Avatar
Harte3
Any tranny that fits a small block Ford V8 fits the 300.
Old Nov 28, 2011 | 03:36 AM
jem44357's Avatar
jem44357
309 cid with moderate head work EFI exhaust capped with Super Trapp disc's inserts to get the right "toune" a cam with just the right grind. Weber style TBI & DUI distributor with a decent control system for the pair. I'd bolt on a TCI AODE. I'd have it spinin' 355 gears. Oh yeah! just for kicks a TCI Outlaw shifter with paddles on the wheel. I'd put it all in a 2200 lbs FFR Roadster just ta see what it could do. Maybe someday spice it up with a turbo but I don't think I'd need it.
Jim
