fuel pump advise??
Old Nov 23, 2011 | 09:03 PM
disco biscuit's Avatar
disco biscuit
fuel pump advise??
Pulled the mask off vader the other day cause diesel was drippin off the valley and such. This trucks been sittin for four years while I chased problems and procrastinated mostly, so I wanna go ahead and do fuel bowl, pump, and everything else that requires takin the star wars mask off.
I need to know if there is some sort of upgrade and or mod fuel pump. I'm stock now but intend to order bowl o-rings, 3in down pipe and 6637(?) From riff-raff maybe....intend to do a 6 pos? after the bugs are gone.
Good advice from good peoples is priceless, I thank & worship you all
Old Nov 23, 2011 | 09:05 PM
fordpride's Avatar
fordpride
no just stock replacement pumps is all you will find
Old Nov 23, 2011 | 09:37 PM
disco biscuit
What would be a good name brand of pump to get? Does it come with a new banjo washer.
Also is it driven by a lobe on the cam or a type of gear that might need to be checked for lift or cleaned?
Thanks again for ya'lls time
Old Nov 23, 2011 | 09:41 PM
fordpride's Avatar
fordpride
from what i've seen they are all made by the same company so just find the cheap one
does not come with washers
it's driving by the cam
Old Nov 24, 2011 | 12:03 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here you go.
Riffraff Diesel: OEM 94-97 Mechanical Fuel Pump
Riffraff Diesel: Banjo Bolt Gaskets
Old Nov 24, 2011 | 12:11 AM
disco biscuit
Originally Posted by Riffraff Performance
I just went to your website and ordered everything. 300$ wasn't too bad for pump, bowl o-rings(blue), 6637 air, hoses, pressure fittings, new schrader, some other things I'll edit in later.
Throw a 3in down pipe for me, I wanted to research 3in vs 4in downpipe and if its worth going 4in for my application
I'll let everyone know how the project goes and try to get pics of my mechanical declination
Old Nov 24, 2011 | 12:16 AM
disco biscuit
I mispelled avice
Advise
No
ADVICE
Hate it when that happens. How do you edit the title of this thread
Old Nov 24, 2011 | 01:50 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Good stuff man. Keep us updated on how it goes and any questions you got.
Old Nov 24, 2011 | 09:28 AM
DIYMechanic's Avatar
DIYMechanic
4" DP isn't worth it IMO. Plenty of guys making 400+HP on a 3" DP to a 4" straight exhaust. Add to that the fact that fairly substantial firewall "modifications" have to be made to fit a 4" DP and it's just not worth it unless you're looking for really high HP numbers and willing to spend $$ to get you there.
Old Nov 24, 2011 | 12:15 PM
disco biscuit
Thx so much for that. Kinda what I was thinkin. I don't see myself goin too big. I do plan to mod it and rebuild turbo. Slight injector work probably. Just enough increase in power to be efficient is what I'm lookking for. I ain't gonna be doin 4lo launches or anything. If I was to go big anyways I would prefer two turbos and two 3in downpipes maybe.
Thx for ya'lls feedback.. if you can think of anything else I need to do while under the mask...feel free to suggest. Im open to all knowledge.
Old Nov 24, 2011 | 12:43 PM
Ford4Life7.3
On diesels, the results are better if you do them in series, one small turbo and one bigger turbo, right after one another, verses what you see in parallel setups, like one on each side. Just a thought
Old Nov 24, 2011 | 02:36 PM
DIYMechanic
FWIW, many of us have removed the mask and never put it back on. I still have mine in the loft above the shop, but when I did this motor swap, I removed the mounts for it. Leave it off if you want, but if you're going for that "clean stock" look I guess I can understand that.
Old Nov 24, 2011 | 09:15 PM
oldbird1965's Avatar
oldbird1965
I'm not into clean or pretty, I want it to work!! Anyway, I found a complete exhaust system for sale because a guy wanted a 5". It came with a 3 1/2" DP and it was a real bitch to get in. It took me all day laying in a foot of snow to get it in. I had to bend the crap out of the firewall to get it in. Like what is said above, 3" in just fine.
Old Nov 25, 2011 | 12:06 AM
disco biscuit
That's good to know even 3.5 is pushin it...guess I'll stick to 3. I got it straight already past the down pipe. While we're on the subject which brand d.p. has worked the best. Do you have to modify where it ties in under the truck. For length or anything?
Old Nov 25, 2011 | 05:40 AM
427 fordman's Avatar
427 fordman
Lots have had problems fitting the mbrp downpipe. I got a dp from tymar, 3-4 inch, and it fit excellent, although cost a little more.
