Engine trouble codes
Old Nov 23, 2011 | 02:00 PM
cadetspider06's Avatar
cadetspider06
The engine will idle good, but any blip of the throttle will cause the motor to momentarily fall on its face and then come to life. But once it reaches operation temperature, it will not idle at all. Any touching of the throttle will cause the motor to die
Last night my 88 f150 4X4 with a 4.9 I6 was throwing a 67, 84, 22, and 33
I replaced my MAP sensor and blocked my EGR with a Lone Star can patch and now its throwing a 67, 84, and 31
Old Nov 23, 2011 | 10:46 PM
optikal illushun's Avatar
optikal illushun
31 could be from the block EGR. try putting a 1/8" hole to start and go bigger from there. Washers (forget the size) with various holes work awsome. the fit right inside the egr gasket. Did u check the EVP sensor?
67 park-neutral circuit failed not engine related
84 another EGR code. dealing with the solenoids.
suggestion. test the EVP (egr valve position, white sensor on the back of the EGR).
Old Nov 25, 2011 | 02:24 PM
cadetspider06
I replaced the EVP sensor and now I am getting a code 15 which is PCM related. I am completly lost now
Old Nov 25, 2011 | 04:02 PM
optikal illushun
clear codes (disconnect neg bat cable for 15 minutes) and drive it for a while to see what comes back.
Old Nov 27, 2011 | 07:16 PM
cadetspider06
Ok. I can't drive the truck due to fear of leaving the driveway. Once the theromastat opens and the truck dies. Will the trcuk throw the same codes without driving it?
minnesotafisherman
15
Dec 10, 2013 06:55 PM
doodad
Aug 24, 2005 10:10 PM
gjordan456
1978 - 1996 Big Bronco
Mar 30, 2005 11:00 PM
kc5deb
1997 - 2003 F150
Dec 9, 2004 08:50 PM
boond0cksaint
Jul 17, 2004 09:23 PM
