steering stabelizers
Old Nov 23, 2011 | 10:02 AM
1bigjoe's Avatar
1bigjoe
i have f350 4x4. don't do alot of offroad.
i see alot of trucks with shock type front end stabilizers
are any of you useing them?
do you prefer one brand over an other?
i have had death wobbel issues just replaced , front shocks ,drag linls , rod ends. gotta find local shop that get my crwcab longbed on there lift
ang get it aligned
but was thinging stabilizers
Old Nov 23, 2011 | 10:49 AM
ihateminimumwage's Avatar
ihateminimumwage
Stabilizers only cover up the problem you're having. How are the bushings on the trac-bar? Bushings in the leaf springs? Are you getting the wobble at higher speeds, or low speed (especially after hitting a bump)?
Old Nov 23, 2011 | 11:04 AM
91dirtydiesel's Avatar
91dirtydiesel
Dual stabilizer
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=steering.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/steering.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Nov 24, 2011 | 06:45 AM
1bigjoe's Avatar
1bigjoe
jsut replaced the track bar bushings.
bushings in leaf ????? i'll check those ,didn't know there were any .
hay 91dirtydiesel can you take some more pictures, that one is kind of shadowed
thanks
Old Nov 24, 2011 | 08:57 AM
greywynd's Avatar
greywynd
I would also go over the king pins, bearings, bushings etc. I have the same truck right now with similar issues, and that's where I'm starting.
Old Nov 24, 2011 | 11:31 AM
1bigjoe's Avatar
1bigjoe
graywynd,
could you take pictures as your doing the king pins,
i never touched a king pin before, i will tackel anything, just wouldn't know how
Old Nov 24, 2011 | 11:36 AM
91dirtydiesel
HeRe is what's under the cap on the axle.
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=6285288c.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/6285288c.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Nov 24, 2011 | 11:38 AM
91dirtydiesel
thanks
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=a50a3ee8.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/a50a3ee8.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=50c9d36c.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/50c9d36c.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Nov 24, 2011 | 11:49 AM
1bigjoe's Avatar
1bigjoe
thanks for the pics, what is the shock bracket,attached to in the first picture, where did you buy that set up
Old Nov 24, 2011 | 12:13 PM
91dirtydiesel
Get what? The bracket? The steering? The stabilizers?
Old Nov 24, 2011 | 12:29 PM
joe f350's Avatar
joe f350
the lower is the factory one the hight one is his custom one lol
Old Nov 24, 2011 | 12:55 PM
greywynd's Avatar
greywynd
I don't know when I'm going to get into mine, working 7 days a week right now. There's a good how-to article online I'll try to post a link to when I'm on a computer later tonight.
Old Nov 25, 2011 | 06:07 AM
1bigjoe's Avatar
1bigjoe
dirtydiesel
the brackets , is that a kit ? or is that something you got the parts from a hardwere store?
looks like the one side, u-bolts to drag link, but i can't make out were the sie by the tire is going to
Old Nov 25, 2011 | 06:15 AM
1bigjoe's Avatar
1bigjoe
i know i need to do somthing soon,
comming home on turkey day was the ride from hell, at 25 mph , shake rattle & roll
scarry ****, the only way ,to make it go away is to stop,
i know a lot of you guys live in the country, but here in dirty jerzy, you got to go 75 & thats in the school zone,
Old Nov 25, 2011 | 07:37 AM
tecgod13's Avatar
tecgod13
Shim the kingpin. Basically put another washer under the cap. I did that to mine and it really cut down on the death wobble. It might not be the best fix or the real solution, but it drastically cut down on death wobble (like 99.9% better).
