HPOP Pressure Test
Old Nov 23, 2011 | 12:39 AM
MauleOne's Avatar
MauleOne
HPOP Pressure Test
Where can I connect a gauge to test the pressure of the HPOP and how high does the gauge have to read to?
Old Nov 23, 2011 | 02:35 AM
BigAlsPSD's Avatar
BigAlsPSD
Hydraulics shop should have a gauge for what you need. At least 3000 psi. You have AE correct? Are you suspecting ICP?
Old Nov 23, 2011 | 07:26 AM
bulla's Avatar
bulla
This is a crappy vid but it shows the materials.
Check out this video on YouTube:
http://www.youtube.com/watch?v=OHcCX...e_gdata_player
Sent from my iPhone
Old Nov 23, 2011 | 08:05 AM
woodnthings's Avatar
woodnthings
You can connect a gauge in each head via the ports in the heads. Just remove the plugs and use #5 ORB adapters to what ever your gauge is. These are the same plugs that get removed to install the HPx cross-over tubes.
Can also disconnect the HPOP hoses off the heads and use adapters (Eaton STC type) to connect a gauge directly to the pump. You can crank the engine and read pressure. You should make sure the gauge is capable of 5,000 PSI. The system can easily hit 3,000 psi.
Old Nov 23, 2011 | 11:58 AM
MauleOne's Avatar
MauleOne
HPOP Port
How about the port just inside valley from the #1 and #2 injector. Isn't that the HPO galley?
I want to make sure my HPOP is good because I suspect everything.
Yes I have AE and am just learning to use it. Will it show HPOP pressure?
Old Nov 23, 2011 | 12:13 PM
woodnthings
Yes, AE will show HPOP Pressure. Use the live data meter to show Injectior Control Pressure.
Here is a article to help. HPOP Health Check
Old Nov 24, 2011 | 02:15 AM
MauleOne's Avatar
MauleOne
HPOP Port
Thanks!
I will learn to use this AE yet!
Old Nov 24, 2011 | 07:05 AM
katula's Avatar
katula
If you decide to use hoses and fittings, be careful. All of the parts must be rated to 3000psi or above. My truck has 300,000 miles, and the hpop gets around 2500psi.......Have a great Turkey Day....:-)
Old Nov 24, 2011 | 07:56 AM
mueckster's Avatar
mueckster
Ken's right. IIRC, the relief pressure of a good hpop is ~3650 psi when it is deadheaded. When working with hydraulics, there's no overkill when it comes to safety.
Old Nov 24, 2011 | 11:24 AM
MauleOne's Avatar
MauleOne
HPOP
I will take a shot at using the AE to check the pressure before I mess with hoses and gauges.
thanks for the concern
bkuuz1
Jul 18, 2014 09:58 PM
helihansen
15
May 25, 2012 12:58 AM
eyyu
Dec 5, 2011 09:05 PM
richdawg
Sep 24, 2010 10:42 PM
kirkharrod
26
Jun 12, 2009 12:58 PM
