cooling system corrosion
Old Nov 22, 2011 | 11:57 PM
01 super's Avatar
01 super
So tonight after having enough of a slow coolant leak, I took off the thermostat housing to replace the o ring. Long story short, I take out the thermostat to take a look and what do I see? Pits in the water pump case!
So I take a dentist pick and start scratching at them and they are all at least .025 deep. About half a dozen the size of a OO buck shot. What the heck? Other than the pits the rest of the inside looks brand new as this was a NEW water pump about 2 years ago and I have been running NAPA ELC since then.
Anyone seen similar corrosion in their units? Think it was bad aluminum casting?
With temps dipping down to -40 this past week I just dont need problems like this, ya know?
thanks for the inputs and if ya can, send some warm weather!
Old Nov 23, 2011 | 10:10 AM
DieselCamper01's Avatar
DieselCamper01
I don't have your answers but here is a bump to the top.
Old Nov 24, 2011 | 10:04 AM
dagren99's Avatar
dagren99
I'd test your antifreeze ph, etc. Could be cavitation damage. Just a thought -are you sure you got 100% of the old antifreeze out when you switched? Having the old stuff in the system compromises the elc's protection properties.
Old Nov 24, 2011 | 10:22 AM
microdevil45's Avatar
microdevil45
Was you elc premixed? If it wasn't what water did you mix it with? Distiller, city water, well water? And I agree have your coolant tested to find out why.
Old Nov 24, 2011 | 01:11 PM
01 super's Avatar
01 super
I've always put in distilled water when mixing and does a guy still need to be checking ph when using the ELC stuff I never have, So where do you guys get the additive stuff and test strips?
I was at NAPA yesterday and they showed me what they provide but wanted input from here before going in a particular direction
Thanks
Old Nov 24, 2011 | 01:15 PM
SpringerPop's Avatar
SpringerPop
Why not just send a sample off to Polaris Labs and have it checked?
You could avoid messing it all up if things were already correct, and you started tweaking with the chemistry.
Pop
Old Nov 24, 2011 | 01:39 PM
RainStroked's Avatar
RainStroked
IIRC the ph should be around 6 or higher, I believe most 7.3 guys run around 7-8 on average, but I'm not 100% on those numbers. You could have some old stuff in there, but it's best to get some test strips and know for sure. I use the Wix test strips becuase I use Fleet Charge DCA2 pre-charged conventional, not ELC. My ph usually runs around 7-8, it got down to 6 one time even after a distilled flush, so I picked up a gallon of pre-mixed Fleet Charge a month after my flush and drained a gallon of coolant from my radiator and replaced it with brand new pre-mixed to maintain the additive levels and 50/50 coolant mix. That alone brought me up to a ph of 8 where it sits today. I suspect I had a little old stuff in there at that point.
steelandspeed
20
May 22, 2019 11:48 AM
ontarioford
Nov 28, 2012 07:26 PM
midapo
Mar 6, 2011 10:39 PM
Frank_D
1983 - 2012 Ranger & B-Series
Jan 6, 2010 08:03 PM
Douglas DC-9
Mar 27, 2009 04:48 PM
