5.0 to 5.8 sd?
Old Nov 22, 2011 | 10:20 PM
jhg_12's Avatar
jhg_12
Exclamation 5.0 to 5.8 sd?
I currently have a 93 5.0 sd and i wanna drop in a 90 5.8 that i got would the 5.0 ecu work with the 5.8 if i change the firing order on the distributor? Also im planning to use the 5.0 accessories what additional problems might i run into?
Old Nov 23, 2011 | 10:20 AM
Conanski's Avatar
Conanski
It should run, that vintage 5.8 is no powerhouse so the 5.0 computer won't have much problem adapting. 5.0 accessory brackets should bolt right on, you will have to widen the exhaust Y-pipe... if so equipped.
Old Nov 23, 2011 | 10:28 AM
Kemicalburns's Avatar
Kemicalburns
what tranny do you have in your 93? the 5.0 flexplate/flywheel wont work on the 5.8 just so you know.
if you have the e4od then finding a 5.8/e4od computer should be easy as it was common.
mikeismadness
1978 - 1996 Big Bronco
May 15, 2012 10:18 AM
Bikedude987
Apr 21, 2012 09:37 AM
SCRebel
Jan 2, 2012 09:39 PM
texashottie
Apr 5, 2005 10:14 AM
taurus
24
Jun 11, 2001 11:55 AM
