the rear headrest wasnt hard, it was the front seat one (if you have the middle seat) but anyway they have a button that pushes in right at the base of the headrest (where it meets the chair itself)
If I recall correctly, the rear center headrest has two of those little push in latches, one in each bezel or escutcheon thingie where the rod enters the seat back. Both have to be depressed to remove the headrest. Or maybe that was the front center one? Anyway, I tossed both. If I need to carry six I'll get a bus.
yes, that's the way my Ex's were - some idjut designed it so you had to push both buttons at same time WHILE lifting ?!?! only have two hands last I looked
but I did try pushing both at one time, feeling around it all, never found it...
oh well, just will lay the seat down when lining up the fifth wheel and listen to the idjut backup alarm while the tail gate is down !!!
