Down on power
Old Nov 21, 2011 | 07:37 PM
olddude644's Avatar
olddude644
Down on power
My 1997 7.3 Has no power until completely warm. Then once warm and traveling on the freeway at 65mph I stand on the throttle it bogs down. The rpms come up slow and the boost jumps above 10 psi. The motor shutters and bogs until I back off a little where the power starts up and slowly apply throttle
to get to 80mph. I am using and edge program second stage (plus 80 hp). This seemed to happen just recently and my mileage has dropped to 16 mpg.
Ideas? I am not a seasoned diesel guy.
Old Nov 21, 2011 | 07:56 PM
Brown Falcon's Avatar
Brown Falcon
Could be fuel filter, low fuel pressure, bad injector o-rings, bad IPR o-rings, bad MAP sensor...
Try removing the Edge programmer. They are known to kill these engines.
Old Nov 21, 2011 | 08:19 PM
olddude644's Avatar
olddude644
down on power
I have a Hypertech and will load it. I think most of it happened when I put 5 oz
of Lucas injector cleaner in per tank (15 gal each). Injectors were checked two weeks ago at the dealer and were ok. Also ran good at that time. The ford tech told me to run a cleaner which I did. Thank you for the advice.....
Old Jan 17, 2012 | 05:10 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Know this is a dead post but any update? Im experiencing the same problem...
Old Jan 17, 2012 | 05:31 PM
fordpride's Avatar
fordpride
Mine did this a coue years ago and the pick up in the tanks were clogged
Old Jan 17, 2012 | 05:40 PM
Ford4Life7.3
So i take it you drop the tanks?
Old Jan 17, 2012 | 09:18 PM
Brown Falcon
You CAN drop the tanks, but if they are at all full of fuel they are really heavy and awkward to remove.
A lot of people find it easier to take the bed off instead. Just 6 bolts and 2-3 people can lift it off.
Old Jan 17, 2012 | 09:50 PM
Ford4Life7.3
Thanks, ill keep that in mind. It seems that i just had muddy water in a sensor, i blew them out and used q tips and it seemed to fix my problem.
Old Jan 20, 2012 | 08:38 AM
mezcalero280cal's Avatar
mezcalero280cal
What sensor was it you had to clean ?
Old Jan 20, 2012 | 09:38 AM
Ford4Life7.3
Not sure which it was, i used q tips and my compressor and went through every sensor/plug i saw (theres A LOT). Just unplugged it, used the q tip on the female side if there was a lot of dried mud in it, and then blew out both sides
McCloud853
Mar 24, 2017 08:09 PM
slim613
Aug 21, 2013 07:24 PM
pmbmax
Mar 21, 2009 06:01 PM
CowboyUp1387
Sep 5, 2008 05:39 AM
cobaum
Oct 26, 2005 07:20 PM
