COOLANT CHANGE
Old Nov 21, 2011 | 10:30 AM
hdman6's Avatar
hdman6
Question COOLANT CHANGE
I am due for a coolant change. I had a small leak that seems to have sealed with bars stop leak. So now I want to get that junk outta the system and fill with fresh coolant. Have you guys used the Rotella ELC that is already pre mixed 50/50? I dont want to deal with testing the ph etc. I did have the gold in it from the dealership, but i am planning on doing this myself. thanks Jeff
Old Nov 21, 2011 | 11:59 AM
cj45lc's Avatar
cj45lc
I'd fix whatever was leaking before I put ELC in there
Old Nov 21, 2011 | 06:02 PM
SpringerPop's Avatar
SpringerPop
You're going to find that most of us on this forum are of the mindset of, "Do it right, or don't do it at all".
Find the leak. Don't cut any corners, and do a proper fix before anything else. The cooling system is just TOO important to be finding "the cheap way".
And, before you go too far, don't buy the 50/50 stuff. Get it full-strength. There's a reason, and you'll find out why after fixing the leak and doing a few flushes with DISTILLED water.
Pop
Old Nov 21, 2011 | 06:56 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by hdman6
...with bars stop leak. So now I want to get that junk outta the system...
Jeff, not trying to beat ya over the head brother, but if you have the same opinion as most of us regarding the bars stop leak (IE, that it's junk and shouldn't be in the system) then why did you use it to begin with?
Either way, flush your system ASAP and fix the leak brother. Then check out my thread here: Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Stewart
Old Nov 22, 2011 | 09:42 AM
lhud's Avatar
lhud
Was thinking the same things guys, but didn't wish to hurt his feelings.
Well said guys!
Pitcrw6
46
Jan 2, 2015 01:26 PM
BLKSVT
6.4L Power Stroke Diesel
Oct 10, 2013 03:51 PM
Ajc11892
Jan 4, 2010 01:16 PM
96eddie5.8
1978 - 1996 Big Bronco
May 7, 2005 11:50 PM
jce
Jun 16, 2000 05:16 AM
