Sponsored by: Real Truck
ABS LIGHT?
Old Nov 21, 2011 | 10:22 AM
powerstroker02's Avatar
powerstroker02
ABS LIGHT?
Hello, change the front drivers calliper last thursday, bled the brakes everythings was good, drove 40 kms and the abs light came on, parked it over night then the light went off and came back on a few minute of driving later. Then this morning i drove about 20 kms and the light came on again. Any thoughts on where i should start with this before i go replacing sensors?
Old Nov 21, 2011 | 12:27 PM
volez's Avatar
volez
This samr thing happened to me a month ago and I hooked up my computer and found the drivers side ABS sensor bad -- I replaced it and everything was fine.
Old Nov 21, 2011 | 12:39 PM
powerstroker02
will a reguler ob2 reader pick it up or does it need to go to a real scanner to find the problem?
Old Nov 21, 2011 | 02:17 PM
volez's Avatar
volez
I dont think those will tell you which side it is
Old Nov 21, 2011 | 02:31 PM
volez's Avatar
volez
Have you checked for a bad bearing? That was bad on the side the sensor showed.
I am guessing a front sensor since you had recent work done. Make sure you dont have a pinched or worn sensor wire. Would hurt to hook up a sensor and see if it throws a code at you
cash142
Mar 20, 2011 01:19 PM
Bohicarlp
1997 - 2003 F150
Jul 13, 2009 08:38 PM
Country4.2
1997 - 2003 F150
Jun 12, 2006 09:54 AM
