Won't start
Old Nov 21, 2011 | 01:46 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by cord812
remove plug in HPOP reservoir make sure it is full of engine oil.
make sure you put cap back on before starting engine.
Great suggestion!
O-ring's Avatar
O-ring
Ok just had my wife check and there is white smoke coming out while cranking. There is plenty of fuel and oil. All the fuses under the hood look good. Is there anything else I need to check?
Old Nov 21, 2011 | 01:49 PM
O-ring's Avatar
O-ring
Sorry for the double post. Stupid question for a diesel newbie. Where is the hpop
Shake-N-Bake
Ok good.
Plug it in for a while and see if it starts.
While waiting, read this thread on the GP system.
https://www.ford-trucks.com/forums/7...pr-system.html
Old Nov 21, 2011 | 01:53 PM
Shake-N-Bake
HPOP (High Pressure Oil Pump) is located on top of the engine under your fuel filter bowl. The fuel filter is bolted to the HPOP reservoir which is directly under your plastic engine cover. There is a allen drive plug that you can remove and check the level of the reservoir only while the engine is off. It's pressurized when the engine is running. Here are some pics...
Old Nov 21, 2011 | 02:26 PM
O-ring's Avatar
O-ring
Pretty sure it's a battery issue. One question. Are both batteries interconnected or independent? I checked the hpop and it's full of oil. It's almost to fully cranked while jumping it off. Once I get this cranked I'm heading to autozone as these batteries are only 3 months old
Old Nov 21, 2011 | 03:00 PM
O-ring's Avatar
O-ring
Yep. Got it started by jumping both batteries
Old Nov 21, 2011 | 04:57 PM
Shake-N-Bake
Good news.
To answer your previous question....both batteries are connected in parallel so it still is a 12v system but you have more amps on tap.
I have always replaced them in pairs, even if just one is bad.
Old Nov 21, 2011 | 05:05 PM
O-ring's Avatar
O-ring
Thanks for your help guys learned a lot. The batteries check out good. Terminals look awful when we pulled the off to inspect
DaveDavis
Jan 22, 2019 07:02 PM
DeanFrank
2009 - 2014 F150
Jul 26, 2017 07:23 PM
Amart927
Jan 8, 2015 05:49 AM
bobbyt89
Dec 2, 2012 09:16 PM
yungun
1997 - 2003 F150
Nov 9, 2011 09:25 PM
