Running Tool Kit
Old Nov 22, 2011 | 12:55 AM
91dirtydiesel's Avatar
91dirtydiesel
All fluids, belts, tool set, jumper cables, fire extinguisher, toe strap, tow chains, air compressor, rope, flashlight, flares, various electrical stuff and a fifth of JD!
Old Nov 22, 2011 | 06:22 AM
snaponprofile's Avatar
snaponprofile
Originally Posted by Scratcher
I'm scratching my head wondering what possible use a chainsaw is if you breakdown
Originally Posted by IDIDieselJohn
Hes in some kind of tree business
You guys crack me up. I don't have a tree buisness, I had to log a large area on my land once so I never stopped carrying them around.
Old Nov 22, 2011 | 06:26 AM
NorthernDiesel's Avatar
NorthernDiesel
Fluids, Breaker bar and sockets, short piece of wire (so I can prime / turn it over from under the hood), can of ether (never used - just in case), dual 48" Hi-Lift jacks, full set of recovery gear, shovel, flashlights, VHF radio and Sat phone.
Bent piece of wire in the bed so I can push the "unlock" button through the vent window seal (due to past bad experience).
Old Nov 22, 2011 | 06:28 AM
Scratcher's Avatar
Scratcher
OK that's sounds reasonable now. You never know when around the next bend you might find a downed tree blocking the road.
Old Nov 22, 2011 | 09:36 AM
Country_boy_2007's Avatar
Country_boy_2007
oh i also have a 10 ton bottle jack, a chain fall, several chains and straps, belts, hoses fluids, zip ties, baleing wire and duct tape...pretty much anything i could possibly to fix, break, lift lower pull, push or otherwise relocate a truck or tractor
Larrymac52
Feb 6, 2018 11:07 PM
joezzz
Nov 17, 2013 12:52 PM
liftedwhitef150
Garage & Workshop
19
Aug 9, 2004 10:11 AM
Screwchief
2004 - 2008 F150
Mar 31, 2004 07:37 PM
