someone please help me
Old Apr 13, 2003 | 06:33 PM
driver4022's Avatar
driver4022
i got a sloppy shifting aod tranny in my 91 f150, can i tighten up the shifts without buying a kit or sending it to a tranny shop?
Old Apr 13, 2003 | 07:54 PM
Tdvjensen's Avatar
Tdvjensen
Check your fluid, and the only way to tighten up the shifts is to buy a shift kit, and if you take it to a tranny shop, they buy the shift kit and install it for you
Old Apr 18, 2003 | 08:58 PM
bill_s's Avatar
bill_s
Line pressure, and therefore shift stiffness is controlled by the throttle valve linkage on the AOD. Make sure this is adjusted properly - if its on the low side, youi could be slipping in gear, which will burn up your tranny pronto.
