production engine in 1991 van
Old Apr 13, 2003 | 06:18 PM
camarokid81's Avatar
camarokid81
if i was to get a ford production ho engine from motorspot. witch i think is a roller motor and was to put that engine in my van and use all stock accessories induction computer intakes and emission controls. truck has duel opening throttle body (speed densidy) will it work with out having problems with computer ?
will all the 1991 van parts fit the engine? if not what will i need to convert it over? what computers problems can i expect using this kind of setup ? can i use the cam that is in it i think it is a explorer cam if i`am not mistaken thanks for reading
Old Apr 13, 2003 | 06:30 PM
mantta's Avatar
mantta
The HO engine has a different firing order than the regular 5.0. This meand you have to have a computer to match it.
Old Apr 13, 2003 | 06:40 PM
camarokid81
do you mean injector fire order of ignition fire order??
Old Apr 13, 2003 | 06:42 PM
mantta's Avatar
mantta
When the ignition firing order is different, so will the injector opening order be different.
Old Apr 13, 2003 | 06:45 PM
camarokid81
doe this mean i can get a computer from a 351w van and it will work??
Old Apr 13, 2003 | 06:48 PM
mantta's Avatar
mantta
The 351W does have the same firing order as the 5.0HO, I am not sure if the computer will work though. I see no reason for it not to.
Old Apr 13, 2003 | 07:15 PM
EPNCSU2006's Avatar
EPNCSU2006
The van should have the bank fire sequence on the injectors, so that shouldn't matter. Just make sure you have your spark plug wires matching the firing order of the HO motor.
