hello guys, i'm new to this blog but have been on the 51 fourm. i just started 0n a 67 and would like to stay as original as possible. it has the 240 with 3on the tree, short w/b, lunar green ext. same on dash and int. except the steering coulum and steering wheel that are a darker green. was this original? also does anyone know the original engine colors? block,valve cover ect. i'm still in the body work stage,engine rebuild ect. look forward to any help i can get.
I dunno exactly what is correct but the darker Ford blue didn't come online until 66 or 67. Below are some pics for inspiration.
A couple of notes:
1. The fan spacer should be cast aluminum
2. The coil should be black with a mustard yellow top
3. The distributor cap should be black.
4. Of course that's not the period correct air cleaner. A period-correct and good looking aftermarket one is a 14-inch open element (ala Mustang "Hi-Po") with a 3-inch tall element. Get one from Mustangs Plus for $22 but it comes with a 2-inch tall element.
Lemme know if you need more pics... I have taken many for reference.
